stone1978
- Mar 10, 2007
Not sure leh. I tried using my Huawei charger. LolI think need to use charger with Power Delivery?
Not sure if its me but there seems to be an overhaul in their labelling. e.g Legion 7i, 5i, 5Pi...Quite true. Now buyer dilemma is 5 pro vs Legion 7 since pricing is similar. I was contemplating getting legion 7 but worried about the hinge issues where it broke easily on the legion7i model.
Dont worry, i also haven buy anything yet .Quite true. Now buyer dilemma is 5 pro vs Legion 7 since pricing is similar. I was contemplating getting legion 7 but worried about the hinge issues where it broke easily on the legion7i model.
I think it's the other way around. Using numbers in brand name is smart. It indicates whether the product line up is low/mid/high end alreadyNot sure if its me but there seems to be an overhaul in their labelling. e.g Legion 7i, 5i, 5Pi...
Did anyone received a "nahimic" audio update?
What are your versions? mine is 1.6.5
Legion 5 Pro.
I think HP best in labelling. The rest of the company to complicated.I think it's the other way around. Using numbers in brand name is smart. It indicates whether the product line up is low/mid/high end already
Intel Core i3 --> i5 --> i7
Ryzen 3 --> 5 --> 7
RTX 3060 --> 3070 --> 3080
Legion 5 --> 7
Look at Asus, who knows what's the difference between Zephyrus vs ROG? or MSI even worse, what's the heck is GL/GP/GE/GS laptops
7i 5i came because Intel used to be a de facto choice of mobile processor last 20 years. Now the tide has turned & the default choice is AMD, i minor indicate Intel version.
5P is predecessor of 5 Pro, now no more. If there's Intel version for 5 Pro, it should be 5i Pro
My Nahimic version 1.6.5. Actually I always use Dolby Atmos setting for gaming.You quote my reply? I referenced
You quote my reply?
I see thanks.My Nahimic version 1.6.5. Actually I always use Dolby Atmos setting for gaming.
No problemo.I see thanks.
Haha new to this PD charging as well. I think need this kind of PD supported chargerNot sure leh. I tried using my Huawei charger. Lol
You can try chatting directly with their sales representative for a discount.Lenovo seemed to removed all promo code
Oo usually how many % they give?You can try chatting directly with their sales representative for a discount.
Wow nice! How did you do that? Did they ask you to create Pro account? CuriousI managed to squeeze them 15%.
I just told the sales to do better than the "SHOPBACKAMD" discount voucher....Wow nice! How did you do that? Did they ask you to create Pro account? Curious
cool thanks, will try to squeeze them heheI just told the sales to do better than the "SHOPBACKAMD" discount voucher....
Max support 100W PD only, recommend RAVPower 90W or Choetech 100WHaha new to this PD charging as well. I think need this kind of PD supported charger
https://www.lazada.sg/products/base...for-laptop-tablet-i973988711-s3490374027.html
My 15% was yesterday thing. Bought the $2799 legion 5 pro. Maybe I was luckycool thanks, will try to squeeze them hehe
Edited: I just asked 1 CS agent just now, they refused twice to offer even 10% discount
