- Mar 22, 2011
anyone have successfully switched from 50GB plan to 80GB plan?
Depends on whether you like to pay $5 (senior plan) or $10 (normal plan) per month..... Lite user normally means less than 20GB per month right?Hi, compare the senior plan (20 GB) vs the 50GB which is better? I am a lite user and dont use the phone much. Thanks.
The senior plan end this july and will increase to $10.Depends on whether you like to pay $5 (senior plan) or $10 (normal plan) per month..... Lite user normally means less than 20GB per month right?
April/May/June/July: 4 months saved $20 already. Anyway, it's individual's choice to select $5 or $10 plan.The senior plan end this july and will increase to $10.
Hi, I just switched to TPG and found that my home Singtel landline cannot call the ported-over TPG number, although another mobile number can call the ported-over TPG number.
Emailed TPG but their replies are very slow.
Searched this thread and last mention of this issue was oct 2020.
Does any guru here know of a solution? Does TPG has a live help desk or counter to go to? Or should I just jump ship to another telco asap? Thanks!
Seems like it! I logged into the portal and saw 100gbDo existing 50 GB subscribers also get the extra 50 GB? Thanks
I saw my 100 GB alsoSeems like it! I logged into the portal and saw 100gb![]()
About 3 months
same view as youi too see it as a gimmick. 99.9% of customers will not use the extra 50gb, so it is of no costs to them.
Yes just some marketing Gimmick.i too see it as a gimmick. 99.9% of customers will not use the extra 50gb, so it is of no costs to them.
