OnePlus 7T
memento85
anyone got issue bluetooth turn on and off?
Try disabling the TraceTogether App if you are using it.
This app will always disconnect my bluetooth if I am in high density people area.
There has been numerous complain in the TraceTogether app regarding the bluetooth.
Do leave review in the app if you are facing bluetooth issue.
Descay
OxygenOS 11 has arrived for OnePlus 7T. Install the Oxygen Updater app on your Oneplus 7T to update the OS.
Finally, it is here. 😆
SG_RedJohn
Anyone managed to enable back VOLTE on OOS11?
Yes..... https: / / forum.xda-developers.com/t/guide-activate-volte-vowifi-oos-11-ob1-ob2.4223967/
Don't blame me if your phone go up lorry.....
I have successfully activated VoLTE & VoWiFi on my OP7Tpro (OOS11).....
coldboy
Thanks. Works for OP7 Pro too.
ashketchum
Holy **** guys DON'T UPDATE to Oxygen 11. I'm using the OnePlus 7T Pro and updated to Android 11 and it's crazy buggy. My WiFi now refuses to connect for some reason, tried whatever fix including factory reset but still the same issue, fkin frustrating. My other devices connects perfectly fine so definitely not my WiFi problem.
When it does connect, it will stay connected for like 10min before it disconnects again. Apparently lots of other users on reddit and OP forums face the same problem. OP still refuses to acknowledge the issue, since there's no mention of the fix incoming. I'm using mobile data now... Zzz
lousydrinker
Seems like OP really getting sloppy. Haiz... Time to move on
Sauron
Facing this WiFi too. Keeps toggling between WiFi and 4G, while all other devices at home are working fine
Sauron
Just install a system update 11.0.0.2 HD65BA. Hopefully can resolve wifi toggling issues
Uramasa
updated to the latest patch 11.0.0.2.
However, need to redo the VoLTE manual patch again.
Avonez
Updated to OS 11.0.0.2. Experiencing the intermittent dropped wifi connections too. That's bad.
leaving_footsteps
Thanks. They have SG carriers profile now!
SG_RedJohn
You are welcome....
I am using the "apac vodafone commerci india" profile for TPG carrier....
Just curious.... what other profiles you guys successfully used for TPG carrier.....
