DBS digiportfolio
Joe Maya
Global Portfolio really chiong now up 6%
Asia Portfolio really slow, up only 1.5%.
Will it go down or go up after they rebalance ?
eAtNeAt
Weird the digiportfolio section disappeared in the app. Anyone else encounter this?
TehSi99
When did you invest?
If i am correct, the value of your holdings should be almost the same after rebalancing.
Joe Maya
My small brother complain Stashaway v slow. So mean DBS Digi banking global portfolio is better than most other robo-advisors in the market?
dappermen
DBS Digi banking global portfolio is better than most other robo-advisors in the market? My small brother complain Stashaway v slow.
i will nt assume tt evn if there is a Side-by-side comparisn
Your younger bro invested in Stashwy 's highest risk ? - when? time wt ret. is how much%?
& any1 who blindly enter around jul to dec 2020 will nevr miss it...i felt
my syfe eq100 time wt ret is
more thn 25% , pf / cummulatv ret is 18% (Sep is just 3 mths away fr ur dec)
So is DBS better?
my SA (36% risk)is 47% (Time wt) inv since nov 2018)- weakr than SYFe of cos but if compared to dbs ,then i m nt sure?
We r talkg abt LOng term - nt just a fw mths!
& r your Robo able to ride out the pandemic or tot wipeout?
Global Portfolio really chiong now up 6% -12apr
inv End Dec last year.
End Dec is a good time to start to invest as it is a low point.
vegavega25
when is the rebalance going to happen?
Rebalancing of your portfolio(s) may occur in any one of the following periods:​
Rebalancing
*Estimated Start Date
*Estimated End Date
First Round13 April 202120 April 2021
Second Round (Only for portfolios that were unsuccessfully rebalanced in the first round)
20 April 2021​
27 April 2021
direbmem
There is no minimum sum to top up after the initial minimum S$1000 investment right for Asia portfolio? So technically speaking, I can just top up S$1 only everyday if I want to right?
Leaden
Yeah possible to top up just $1.
but after every top up they will freeze both the top up and withdraw function for up to a few days, for them to rebalance your portfolio.
direbmem
So the closest interval for top up is every 2-3 days? Not possible to top up everyday?
TehSi99
USD to SGD keeps going down. Still worth to invest in this digiportfolio?
Means we pay more to invest and get less when redeem.
vegavega25
Depends on when you redeem, no? And therefore on your investment time frame.
In my view, you should invest in the currency that you know you will need at the time of redemption. There is enough uncertainty in the world as is, for currency fluctuations to not be added to the mix.
yuzu28
Choose those that are in SGD, though the stuff they invested are in usd. Probably some are hedged?
