OnePlus 9
iakey83
Did you guys buy the export set from q10?
How's the performance so far? Saw some review that after patch many things improve.. battery, camera etc
Shutter lag is still there though..
I have messaged lazada official store, they will carry local set in May.
maumu
Shutter lag still present? :O
Thanks for asking the official store, hopefully it's true (coming in May).
GardeniaOverSunshine
Yes it is still there, refer to this video made on this youtube about the latest update, 1.45 min.
Guys I wanna ask, some of u mentioned that the China set this year since it is ColorOS, by flashing it to OOS will impact the imei? Sorry not too good with these.
Previously bought OP5 the same way, thru qoo10 and the fella flashed for me. So wondering if its the same for this generation, can i simply buy from qoo10 the OP9pro and after flashing, will it impact anything.
Also - since OP8 and OP8pro already have Volte and 5G, once OP9 officially release in SG, after awhile logically the telco should carry those functions on op9 right, or nobody has any idea as well.
mosprockett
Got one seller selling CN global rom sets. Says IMEI not broken. Worth to try?
Shop at SLS. Will drop by to take a look
jesongaudan
I also bought from Win Digital and mine is a non genuine imei. My 1st op9 pro from 131 is fine though
You are right. I've check the imei on my phone against imei pasted on the box is different. But everything is working flawlessly even VoLte is also working. My concern is only 5G. Have to wait for local release I think.
maumu
Phone imei dun tally with the one on box
i won't wanna spend > 1k on such a dodgy label... even if it's working now. when need to send for servicing, how? actually, where's the official service centre for oneplus?
garychengjw
non genuine imei or imei lost?
i read somehow if flash china set coloros to oxygenos, imei will either corrupt or lost.
garychengjw
export set usually go back to seller's shop = shop warranty.
tkte_85
Its not technically lost, but both imei number are the same (and different from the box label), so i defined it as "fake". BTW, i flashed it back to colorOS and its showing the imei are fine, just e moment u flash back to oxygenOS, its back to the non-original imei. Its said to be getting fixed in future oxygenOS update, but dunno when.
Also, my 1st OP9 Pro from 131 has no such issues. The win digital one, along with most other OP9Pro in the market, have this issue right now
maumu
Its not technically lost, but both imei number are the same, so i defined it as "fake". BTW, i flashed it back to colorOS and its showing the imei are fine, just e moment u flash back to oxygenOS, its back to the non-original imei. Its said to be getting fixed in future oxygenOS update, but dunno when.
so it's not wise to buy export set from china I conclude?
will wait patiently for local sets to be available.. (while pondering over sony's just released xperia 1 mark iii)
garychengjw
not properly flash by other seller?
KeYoKe
Better dont. Imei number lost can have lots of implications...
tkte_85
they probably followed the instructions on OP's telegram which i am also in. Like i said, IMEI is not really lost, its somehow not the correct ones in oxygenOS, which when flashed back to colorOS, the IMEI's fine
mosprockett
So means 131 one the imei for OxyygenOS matches the box?
Which shop is 131 btw?
Also what happens if u flash back 131 phone to ColorOS, then back to Oxygen? Will the imei still be OK?
