Pocophone F3
cch0707
Because that first batch was the affected batch which had the exploding Vivo phones and unfortunately got delayed.
4.4 batch no problem or had no Vivo exploding phones so reached earlier lor.
The exploding phones was 10 April.
Those who ordered on 4 April got F3 on 9/10 April in their SG home.
Xiaomi screwed up its logistics..Period.
KeYoKe
So how you compare this with redmi note 10 pro? Is it noticeably faster?
Quite noticeable especially when switching between apps and apps launch faster on poco f3
I also noticed the screen is better on poco... :s13: looks sharper and color looks nicer
TechNuB
Any 1 had battery drain on idle issues???
My phone battery drain 23% after 8 hrs idle
xKazeolus
reporting..
65W GaN + 5A USB A to C can achieve Mi Turbo Charge (~16W) but the charging seem slower than when im using my USB C to C cable which only have Quick Charging.
stillgottheblues
I didn't notice screen difference, and spores wise when doing daily stuff is the same, less than 1 sec diff only.
ceestudent
Debloat bro... Mine drain 1 percent for a 7hour sleep
May I know which apps is safe to uninstall with the ADB debloat? some of the apps i don't really recognized, worry it will soft brick my phone. Thanks.
KeYoKe
The list was shared a few pages back by a bro here. Those are basically safe to remove bro
Dont remove the Mi security app. That will cause bootloop
shenme22
Hi guys, I got my Poco F3 on Monday, but I've run into some issues. In the 5 days I've been using it and I've had an issue with the phone doing things on its own like calling people, or texting people, even when it was locked and in my pocket. It even changed my google account settings. I don't really know what to do because I'm a first time xiaomi user, and I've done basic virus checks with 3rd party apps like Eset to no avail. Any experienced bros can help me out ? very frustrating. thanks
xKazeolus
[Findings] Themes - Session expired. Please sign in again.
If any bros kena this:
1. Uninstall updates.
2. Clear data/cache
xKazeolus
can leave the phone alone for a period of time (at the side beside you when you can glance it) and see if it will auto call people? i hope the texting ppl part is not proper sentences .. :x
if dont want to waste time, i will personally restore factory settings and re-set up @ its minimal and use it for a few days to see if problem persist.
