ceestudent
- Apr 13, 2010
Really got see the different after debloat. My battery only drop 5% overnight, previously was 10%+. Shall monitor this few days.
Told u debloat works wonderReally got see the different after debloat. My battery only drop 5% overnight, previously was 10%+. Shall monitor this few days.
I am almost monitoring black 256 to go below $500...still waiting for 256gb white below $500
i debloated and everything, keep it power saver mode all the time, etc overnight only drop 2% even with notifications coming in LOLReally got see the different after debloat. My battery only drop 5% overnight, previously was 10%+. Shall monitor this few days.
long time no open my xiaomiadbfastboot lol. since i last had to change rom on my redmi note 5.Told u debloat works wonder![]()
i change from default 392 to 420. on both my poco f3 and f1any bros play with DPI settings?
bros using nova launcher prime, do you encounter double tap to screen lock will randomly not working due to accessibility and also cannot pull down notification shade?
Mine drop 2 to 3 percent for 7 to 8 hour sleep. If airplane mode 1 percent maxlong time no open my xiaomiadbfastboot lol. since i last had to change rom on my redmi note 5.
debloated see how it goes now, last night drop 10%
Mine is sim wallet. Working fineStill no luck with GPay for bus/MRT sia, getting the This didn't work message. Contactless payments are fine though. Under NFC settings, SIM Wallet or HCE Wallet?
Read HWZ Forum Rules!
i think any higher would be kind of too small for my taste. i tested a few numbers and prefered ~420any reason for 420? i started with 480 and now experimenting 450. haha..
What are those app you guy removed thru debloat?
90 percent is inside. Just remove those that is in the list lor^ not all of the apps will be in your poco.
there wasnt browser, mi AI and translation service
