in terms of pricing, you probably will never see that as a strong point for Apple's products.isn't chromecast with google tv a better and cheaper option?
Depends on usage. Airplay 2 is still much superior with the ability to AirPlay 4K/120Hz content directly to the TV. Chromecast is unable to do that.isn't chromecast with google tv a better and cheaper option?
You calibrate the TV, you do it once for many devices. But if you calibrate the device, then you got to do it for every single device.guess gone are the days of calibrating your TV, now we calibrate the device instead.
Apps in Apple TV are also more stable and quality is much better compared to Google TV.
Yup the Apple TV HD onwards. The one using A8 and aboveBased on an article I read, any ATV from 2015 can be calibrated
i'm using chromecast to cast from phone to non-smart tv. i have a apple tv gen 2 now resting inside the cupboard somewhere... lol. the apple remote control is meh.... the apple tv did not give me a good experience.Yes in most cases.
But it still depends on individual use cases.
For example, if you need MeWatch and Singtel Cast, then Chromecast 2020 can only cast from mobile phone.
And if you are really into Apple eco system, then Apple TV is still worth it.
I have old Chromecast 1st gen (occasionally using), old Apple TV 3rd gen (seldom using) and Mi Box S (main TV box).
Chromecast 2020 is kind of Mi Box S killer with the strange exception of SingTel Cast app (SingTel TV Go works).
As for Starhub TV+, none of the TV box works directly (not cast) except Starhub's own lousy Starhub TV+ box.
Apple’s new Siri Remote doesn’t come equipped with an accelerometer or gyroscope, which means it won’t work as a motion controller in certain Apple TV games.
The change means that the new Siri Remote won’t work with certain Apple TV games that rely on motion controls. According to code in tvOS 14.5 seen by MacRumors, trying to play an incompatible game will lead to the following error message: “To play this game on your Apple TV, you need to connect the Apple TV Remote (1st generation) or a compatible PlayStation, Xbox or MFi controller.”
There could be a Pro version targeting gamers with A12X/Z chips and comes with a gaming remote.
It will never beat native solution. Waiting fir Apple gaming controller.
thinking if i shld get one.. need to do some homework on the productAnyone excited about the new Apple TV? Haha
The following article gives a good comparison between the new and the old:thinking if i shld get one.. need to do some homework on the product![]()
https://techforluddites.com/apple-tv-what-is-it-and-how-does-it-work/The following article gives a good comparison between the new and the old:
https://9to5mac.com/2021/04/23/new-apple-tv-4k-vs-old-apple-tv-4k/
Apple TV国行版已通过广电审批,正在等待工信部和3C认证审批,产品内置腾讯视频、喵酷、爱奇艺、哔哩哔哩、央视频、YouTube、Disney、Netflix等,预计在9~11月之间发布
