Pocophone F3
anizee
Starting to get some issues with scrolling and touching. It's like the screen doesn't recognize my touch for like maybe 2-3 seconds then it goes back to normal. Happening frequently enough to annoy me.
2wentythre3
Hello gurus, does anyone also have the RN10Pro? Are their screen protectors generally of the same size and cutout for the Poco F3? Thank you.
Skyy
last night i tried the Ultra Batt Savings mode, lost 3% overnight with data, wifi and BT off.
cch0707
I got 4% from overnight 7 hours. All settings normal, cellular, wifi , bluetooth , nfc on.
FYI - I did disable/off automatic playstore update, wifi assistant which probably helps.
Will continue to monitor and share
Kindovic
mine also sometimes like tat.... esp when touching near the edge...
anizee
Mine is at the whole screen, even the centre of the screen, and frequency is starting to increase. So annoying especially when I am scrolling through a browser page or my emails.
Skyy
why not u go to the CIT page and do a touch sensor test?
anizee
Updated the firmware at the settings page and downloaded the latest firmware package and everything seems fine for now. Will continue to observe.
Skyy
updated the FW? got new FW meh? what version u updated to?
Devilsire
for me not much issues other than 2 game crashes and phone auto reboot once or twice till date.
nfc with UOB ATM now works without need of opening app by setting use default to always instead of replace default when app is opened
battery drain over night probably abit but not a concern since charging is fast
Sent from Poco F3 using EDMWER app!
KeYoKe
For those whom are keen to use 90hz on this phone, download SetEdit app from playstore, search for "User refresh rate", select it, edit value and set to "90"
To set it back to 120hz, can set the value at the SetEdit app, or just select 120hz at the Display > Refresh Rate under Settings
Testing it right now. 90 percent usually i yield 45mins sot, now i yield 1hr 15mins
Cokester
Sianz, last night tio 1 reboot and follow up with a shutdown.
When I thought it was ok after 2 days free from it.
Cokester
So far anyone received the phone le haven't had any random reboot or shutdown ?
Msg shopee Poco and they advise to send in mi service center for checkup.
