Pocophone F3
Hailgod
For those whom are keen to use 90hz on this phone, download SetEdit app from playstore, search for "User refresh rate", select it, edit value and set to "90"
To set it back to 120hz, can set the value at the SetEdit app, or just select 120hz at the Display > Refresh Rate under Settings
Testing it right now. 90 percent usually i yield 45mins sot, now i yield 1hr 15mins
any problems with colour calibration? the grays go noticeably whiter when i open recent apps in 120hz mode when it drops to 90hz. same with my PiP complaint
Hailgod
ok i sat down and tested a few times, i think it does have the slight "white filter" or something on it.
it wont show up on screenshots because its the hardware calibration difference
xenocide
i have not experience any reboot or shutdown at the moment
So far anyone received the phone le haven't had any random reboot or shutdown ?
Msg shopee Poco and they advise to send in mi service center for checkup.
Hailgod
hopefully they will release a rom that fixes all the problems, then i will never update again because xiaomi loves introducing random bugs.
yesterday i see AOD draining my batt in standby. My AOD is off
halocast
touchwood so far none.. but i purely using as a secondary phone. :o
KuroI-Kaze
today taking bus wanna go somewhere .... suddenly gpay not working like some of the bros previously .. the feeling suaksss disappointed.
ceestudent
I think even after clear the gpay and google will still occur after few tap. I give up and use physical card now
KuroI-Kaze
Like no :s13: let me monitor tonight
No choice. Google play service issue... Sigh
After i got the first error i go and press restore nfc functionality to try fixing ... then become cannot detect anything no error no nothing when tabbing :eek:
guess now back to card for the time being ..
anizee
No reboots but random screen sensitivity issue (didn't register my touch) and just now, bus didn't recognize my gpay for the first time. Disappointed with the issues.
garychengjw
Gpay transit is separately issue. Widely affected most android device due to Google Services. (There’s a thread reported on this).
Hailgod
seems like battery/heat management really improved nowadays.
yesterday i play ml till left 10%, charge with a 18w qc 3 charger and played a game (15-20min) and gained 20% without dropping any fps.
if i charge and play on my f1, it will choke to 30fps and batt % wont even go up :s13:
