Just sharing with you guys, my first batch of Taobao screen protectors just arrived. This batch is not the original SP that I ordered separately.
It claims to be PET material but it seems to be mixed a little bit with TPU. The orange peel effect is very minimal, not very noticeable as compared to the Neoflex. With the screen on, it probably feels the same as the original SP and clarity is good. just very tiny orange peel effect when you shine it on a bright light when the screen is off.
Only thing is that it's a bit tricky to apply on. Sides are cut very tight (probably to maximise compatibility with cases) so you need to align properly, while need to make sure no dust seeps in. I ordered 18 pieces and wasted quite a few before I pasted satisfactorily. But the price per piece is cheap la so no issue.
There are some bubbles, which based on previous experience with this same brand, should go away in a few hours.
Link here 6.0!tNZDX3bi9Ud嘻
https://m.tb.cn/h.4rY6WiG?sm=3025ed 适用三星s20原装高清膜note9手机贴Ultra菲林热弯软10+全覆盖出厂
