I thought it will try harder to connect to other bluetooth if it's signal is blocked?Shouldn't be.
How bluetooth itself know signal is blocked?I thought it will try harder to connect to other bluetooth if it's signal is blocked?
The big Dino egg also drain very fast. First batch of Dino egg soup lasted 4-5 months. Then the replacement Dino egg only lasted less than 2 months. I am on the 3rd.i have the small white one
very fast batt flat liao
Keep at home can last very long
lol... u think handphone meh... how it know it's signal is block?
it will just keep sending out the signal see got response anot... same power throughout...
but I think it may consume more power if it has detected a lot of other devices. exchanging of data and writing to its flash all consumes power.
2nd time battery replacement also free?The big Dino egg also drain very fast. First batch of Dino egg soup lasted 4-5 months. Then the replacement Dino egg only lasted less than 2 months. I am on the 3rd.
I replace for all 5 of my family members. The battery life is consistent for each batch.
If it’s battery flat, it’s free. If you lose it, then have to pay.2nd time battery replacement also free?
what battery it uses?I think should be this, too.
Anyway the battery isn't that expensive. I bought ten pieces online. Will own self change when the time comes.
oic. very nice of our govtIf it’s battery flat, it’s free. If you lose it, then have to pay.
