scanner007
- Dec 28, 2020
So far I didn't encounter as mosquito, unless you walk into the park., espcially the weather now is hot and humid.what's the side pathway to LM? i was only walking on the road between LM and the park, and only reached the drive way entrance into LM before turning back. Didn't actually go inside the park itself after all the bites on my missus... i got zero bites though :x
When you walk from Chinatown to LM, 2 paths:
1. Instead of turning into the road between LM and the park, you will see Sheng Siong supermarket, walk towards it and through the HDB block and turn left once reached the end of the block, walk straight until you hit LM. At your right hand side is the CTE.
2. When you walk towards the park from the road, keep to your left, there is a shortcut pavement leading to LM.
Anyway, have fun to explore the area. When I was exploring, I was surprised LM is actually so near to so many popular areas.
ppl swimming still have to get out of the pool eventually mah. not sure how big a source of mosquito is the park.
If you say so, those condos with alot of greens will also have this problem. So far you see anyone complaining? LOL
