Hello gurus, I tried searching for my problem but couldn't find it here, so I'm posting this for help.
I'm on M1's 1Gbps plan, and have their ZenWiFi AC 2-pack router. It goes:
Fibre endpoint > modem > [lan cable] > ZenWifi 1 > [lan cable] > ZenWifi 2 > [lan cable] > PC
The problem is, my PC is only registering speeds of around 93Mbps when connected like this. If I switch off ZenWifi 2 and force my PC to connect to ZenWifi 1 using Wifi, I can get around 400Mbps instead. This has gone on for around a week. Previously, I could get speeds of around 900Mbps instead.
I've tried switching off both routers, but the problem persists. What should I do?
Thanks in advance for the help!
