OnePlus 9
Pukunara
I did a 1 hour test on oneplus 9 pro and it left 60%, heat near cam hovering at 43 degree celsius while opposite side is hovering at 37 degree celsius for max setting
Thanks for testing. Would you consider that as good temp ?
boaboy
I would say its similar to oppo find x3 pro which i did the same 1 hour test. Its acceptable and would recommend using full silicon case if u intend to do gaming for a period of time.
Zinna
12+256
Local ?
1469 at shoppe , tmr have 100 off
https://shopee.sg/product/93785607/7888048908?smtt=0.100000129-1622033901.9
Not sure should hootor not
This one not local, as local don't have pro. Notice in the description they never say anything about warranty. Maybe check with them if they (the shop, since they got physical shop) will provide warranty from their end, or if you buy liao then on your own if any issues.
But at that price its competing with S21 ultra and OPPO find x3, both i feel are slightly better than oneplus
nachocheese
Was hoping op9 pro cld replace by ageing op7 pro. But gave up due to oneplus deteriorating os support for 7pro and less favorable reviews on 9pro. switched to vivo x60 pro+. Hope to use back oxygenos one day
Read HWZ Forum Rules!
iakey83
using op9 for 3 days already.
negatives:
the fingerprint reader is too close to the home button. I've accidentally exit the app too many times when I want to authenticate with fingerprint.
also in one game, there is some touch screen lag
positives:
software - oneplus users will know how good oneplus software is. the little things they do to enhance user experience. in this version, i really like the dual-sim shortcut and work mode feature.
camera - i compare with my wife s21 and honestly i cannot tell the difference. OIS or non-OIS. quality of pictures is the same. oneplus edge out in ultra-wide, s21 edge out in selfie.
battery - i got 8 hrs screen on time, which is enough for one day usage. charging is fantastic, the same charger can be use for laptop as well.
lee-turbo
Mister mobile lo
Was considering findx3 pro but drop it
Never consider ss
K.Chokdee
how is the product positioning of the T series like ?
Is it something in between of the base model and the pro model ?
ie. in between Op9 and Op9pro ?
Zinna
They every time change pattern, but generally can expect it to be between base version and the pro. Usually more value for money compared to the pro
kctankm
Hi guys, need advice here. I just bought Op 9 from shopee official store. Was using Google acc. to setup when the phone just power off and could not power up. Can I ask for a 1 to 1 exchange or get a full refund ? I do not want send it to service center if possible. Any advice greatly appreciated.
Tia
Henderson1
Planning to upgrade my phone from 7 pro to 9 pro. But I've seen alot of issues relate to overheat, does anyone here experienced it too? And how long is the Screen on time ?
