Thanks for your reply. That's sad. Can't self fixone of the backlight LED is starting to fail. it can be replaced but the process is hell cumbersome n theres a risk of cracking the glass panel which is extremely fragile.
Thanks, I understand. A little bit lecehhttps://shopee.sg/product/298874604/3947943776?smtt=0.237167325-1621734889.9
i used this cheap and good ..got 5 button can learn from infrared red remote..only thing is u need a xiaomi phone with mi remote to learn the power button..if not it only can turn off the TV and can't turn on cos once u turn off the TV the WIFI adaptor at the TV no more signal and u have use infrared red to turn on using the programmed power ON from phone mi remote.hope u understand wat I'm saying..i spend quite alot of time to figured out it..cant found it from Internet and YouTube..
Read HWZ Forum Rules!
When I bought last year, it was the 4S... now I think they're selling the 4X... seems to be identical... my experience with the 65" 4S is very positive... good image quality, bright, fast, easy to use, allows me to Chromecast from my tablet, stream from my desktop PC via Kodi, and plug in USB flash drives to play stuff back... and local free to air TV is nice and sharp, the upscaler is pretty good I must say... worth the money... it's more expensive now... about $50 more than last year but still worthwhile... but do note the TV don't have SAFETY MARK... I asked via the Qoo10 chat and the seller simply says it's safe to use... ha ha... means not inspected by Enterprise Singapore? Sounds like that lar... but not completely sure... cosif got SAFETY MARK, sure will just say yes right?
It's either this shop or Minihelpers lor... I rather suspect they have the same source... anyway both bring in the TVs are parallel imports I think... my TV doesn't have the SAFETY MARK that all electrical appliances should bear when sold in Singapore... so if that's important to you, buy from Courts or Xiaomi itself...Looking to buy Xiaomi 43” TV...
Is Qoo10 (Mijia Viomi Official Store) the cheapest one around?
https://m.qoo10.sg/item/OFFICIAL-STORE-XIAOMI-SMART-TV-32-43-50-65-IN-LED-HD-ANDROID/659918161
TIA!
My set broke down the other day. No video and no sound. That was a easy fix. Just change the power supply board and the TV was fixed. Yours could be more complicated. Looks like the set has a T-Con Board problem. Not sure where the 75 inches T-con board is located; for my 55" MITV4, the T-con board is embed right inside the TV screen. Only the wires are leading out. Here is the T-Con in a Sony TV
Anyone pre-ordered the P1 55" TV?
The current offer with free robot vacuum seems like a good deal...
thanks for the advise. The video tutorial shows it’s quite easy to replace. But where do I buy the t-con board? I’m bad at Chinese thus finding it on Taobao is a problem.
how come your "xiaomi flagship store" has no warranty ?bought from Xiaomi flagship store 3 months ago
now the panel is dead. no picture.
called Xiaomi they give me the ping pong treatment.
now 800 down the drain. should have not saved the money, go with better service brands.
That is the issue with good brand but **** service. Apple came to setup store years ago and we didn’t look back. Best for Xiaomi to do the same but Singapore small marketsupposedly got. but until now 2 weeks already, every time I called they said technician will call back, or say need to check,but no response yet.
what is the name of this "flagship" store? is it genuine?That is the issue with good brand but **** service. Apple came to setup store years ago and we didn’t look back. Best for Xiaomi to do the same but Singapore small market
