- Jul 14, 2005
All ok so far broBro, can ask how's the cover for the edge? I'm using the hydrogen gel one but the edge don't seems to cover up properly
Unlock bootloader need pc meh?received my white CN set but have no pc to unlock..... -_-
company PC cant install usb driver zzzzz
I thought press phone can liao?then use what to to unlock?
I never unlock before lol
Saw the option inside phone only
Flash to EU rom, not globalIs buying a china set and flashing to global set ROM same as getting a global set?
As in the firmware/ software...
But I read that Eu ROM need to update manually. Also the seller is offering to flash to global ROM. I hope his global ROM does not mean Eu ROM though..Flash to EU rom, not global
But its as good as global, no diff coz everything can use
can share what case you using? just went down to casefactorie today.All ok so far bro
IIRC everything worksno issues with safe net from the flashing?
just worried there will be issues with apps vs stock global model
Yes EU rom need manual updateBut I read that Eu ROM need to update manually. Also the seller is offering to flash to global ROM. I hope his global ROM does not mean Eu ROM though..
does voice activating the google assistant work?I got my china set today. Tried it, so far like ok leh, without flashing it other ROMs.
Almost all the apps I wanna use, can use. And majority of the stock china apps also can remove, less the factory apps.
Is it still worthwhile to flash to EU ROM? Scare garang gabok.
Ya i heard so far no issue with cn rom nowI got my china set today. Tried it, so far like ok leh, without flashing it other ROMs.
so i have to unlock bootloader and root in order to flash this eu rom??Ya i heard so far no issue with cn rom now
I think they change to EU rom is to prepare for future ba
Keyoke say eu is cleaner
i think the 12/256gb mi 11 ultra is going at 1260ish with coupons and i m so tempted
Buy mai tu liaoso i have to unlock bootloader and root in order to flash this eu rom??
Can share how to get this price? Thank you very much!so i have to unlock bootloader and root in order to flash this eu rom??
