XIAOMI MI 11
tckrto
I thought press phone can liao?
I never unlock before lol
Saw the option inside phone only
Need to use mi unlock tools also.
unlock from phone then load into fastboot plug usb in use me unlock tools to unlock then wait 7 days.
marxace
Is buying a china set and flashing to global set ROM same as getting a global set?
As in the firmware/ software...
ZhuTou!
Flash to EU rom, not global
But its as good as global, no diff coz everything can use
marxace
But I read that Eu ROM need to update manually. Also the seller is offering to flash to global ROM. I hope his global ROM does not mean Eu ROM though..
ZhuTou!
Yes EU rom need manual update
There are 2 types of global rom
1 is under EU and 1 is the standard global which i haven heard before yet
I think ur seller mayb flash to the EU global rom
PSX12345
I got my china set today. Tried it, so far like ok leh, without flashing it other ROMs.
Almost all the apps I wanna use, can use. And majority of the stock china apps also can remove, less the factory apps.
Is it still worthwhile to flash to EU ROM? Scare garang gabok.
TechNuB
I wonder if xiaomi dont care to sell the ultra here or EIN cant be bother to import..
was
does voice activating the google assistant work?
Gpay?
Chromecast controls auto show up in notification page when casting?
ZhuTou!
Ya i heard so far no issue with cn rom now
I think they change to EU rom is to prepare for future ba
Keyoke say eu is cleaner
TechNuB
so i have to unlock bootloader and root in order to flash this eu rom??
i think the 12/256gb mi 11 ultra is going at 1260ish with coupons and i m so tempted
tckrto
Just grab the 512gb the price like 50bucks difference. Don't bother with local distributor anymore. Chips shortage is affecting global set release.
edit: Don't have to root phone. only unlock bootloader and flash xiaomi eu rom.
CN rom works fine if u not using netflix, disney +, so far i cannot unlock and flash as my personal pc send in for repair.
PSX12345
Google Assistant is working, but I can't get it running in background as in when I says "Ok Google", it's not being activated. Not sure what I configured wrongly.
Google pay is working.
Have not tried Chromecast yet.
Netflix, Disney+ are both working fine, so far haven't encounter any problem. Just that the apps are not found in Play store. I have to install from APK files.
Also no issues for my work related apps like Microsoft offices, intune portal.
Azure
Can share how to get this price? Thank you very much!
