looks like it's a no go for me already. could not find the input cable at my dry riser too.
If you only have a single point, even if you can find the incoming at the riser box, not too sure how it going to help at all since you can't connect 2 or more points together (e.g. MoCA between living room and bed room).looks like it's a no go for me already. could not find the input cable at my dry riser too.
Yes that is true. My HDB flat built in 1998 has only one SCV cable entry point in the master room, but the previous owner did the renovation in 2002 and added two more points in the living room and one of the common rooms. The other common room does not have the point.Old HDB do not have coaxial point everywhere. Last time, they offered free for 1st point only. Anything else need to pay. So most old units have only a single point.
Search in Google for "coaxial f-type female" connector to get an idea how it looks like.
So it turns out that my rented flat is so old it doesn't even have coax wiring, or at least the landlord didnt even bother installing because I don't think my neighbours could have lived without cable TV for so long. As such, my only solution is to ask Ayub to lay a cable in my house from the living to the bedroom.
So I now have two goCoax units + a POE filter that I'm willing to let go at a discount. PM me if interested!
is the gocoax still available? mocal 2.5?
I bought one unit of Gocoxial from Amazon US to use with an existing pair from Actiontec 2.0 two months ago. So far, no problems.
Still available? how much you will let go?I bought two units of Gocoax MoCA 2.5 from Amazon. Tested them out once. Working fine. Decided I don't need them as my home is wired with LAN points. Willing to sell them at reasonable price. PM me if interested.
FYI.
https://www.reddit.com/r/HomeNetwor...ere_any_moca_25_adapter_with_a_25_gb/g5j8v4p/
Happen to chance upon the following thread whereby goCoax mentioned that they are working on a 2.5GbE port which should be ready by end of the year.
Not too sure whether that goCoax nick is real and/or schedule has been shifted.
