I wonder is it viable to use the ipad for coding...
Lol!
Seems like this is the new ipad strategy
1. Entry ipad - 10.5”
2. IPad mini - 8.5”
3. IPad Air - 11”
4. IPad Pro - 12.9” mini led
About right. Lol! Can trash all the androids
Does the backlight bleed on the air4, in general?Is the backlight bleed very bad on the air4?
Contemplating to either get the air 4 or the iPad pro 11 (2021)..
If budget is not a concern, I'd go for the Pro...
Try searching for UGreen USB-C to HDMI cable.I moved from the 9.7inch ipad pro to the ipad air 4. The screen is excellent and I did not notice any backlight bleeding.
btw. Does anyone have a recommendation for a budget cable to connect the ipad air 4 to a TV via HDMI?
The original apple one is just way too pricey.
Sure it can be done, but you're going to live with a lot of limitations and frustrations.I wonder is it viable to use the ipad for coding...
Not doubting you. I found this and various others. They don’t specifically say it supports iPad USB C output. Which is why I worry that it will not work.Try searching for UGreen USB-C to HDMI cable.
Actually ugreen got specifyNot doubting you. I found this and various others. They don’t specifically say it supports iPad USB C output. Which is why I worry that it will not work.
I think most get WiFi, but I among a couple of others got Cellular. Depending on your usage, as I got it to use outside mostly, and I don't want to use hotspot.Do Most ppl get Wifi or Celluar?
Cellular is expensive
I got wifi but now kinda regretting and don't mind if someone wants to swap with me (with me topping up of course). Hotspot is a hassleDo Most ppl get Wifi or Celluar?
You can use instant hotspot if both devices using same apple idI got wifi but now kinda regretting and don't mind if someone wants to swap with me (with me topping up of course). Hotspot is a hassle
read an article that says there may not be new iPad Air this year.. not sure how trueIsit too late to buy ipad air now? or should i wait for the 2021 model?
