XIAOMI MI 11
napster79
Guys, I just received mi11 ultra china rom set and I cant dial out using TPG line. Any advice?
Thanks
Edit- 4G data ok to use but not voice and no Volte and TPG 4G voice app stated not supported by my network.
Search for my post yesterday for the code to activate volte and VoWiFi. It might work as I believe TOG needs volte to call out
eS.KuKu
Oh cool. Will check that out thx. They do for u ? Or u diy
they will do for you, 1 thing to take note. bring the casing you be using for the phone. They will align properly for you and also let you know if the case is compatible with the SP.
tckrto
Kelong, i waited mine for 168hours! LOL
Well I not sure why. When was your mi account created? Mine was created when they come to Singapore ard 2014? Then I think around 2016 xiaomi start to lock bootloader. I didn't perform much unlocking until mi9 then now this mi11u. Maybe just lucky I guess.
eS.KuKu
should be around the same time as you. first phone with them was mi3 i think. i only unlock once on my mi6 then until now my ultra lo. just flash to eu.rom yesterday only! feeling shiok
KeYoKe
Hahaha same. Once i got it just flash eu rom :s13:
Now with custom recovery, even better for updating of firmware
superio
Hi bros,
Can I check if the resale value for China rom version will be lower than the SG version?
Asking coz I usually change phone quite frequently, eg. usually 6-12 months.
Need to know as resale value is important to me.
Thank you in advance for your replies!
Zinna
Hi bros,
Resale for xiaomi (and android) generally not that good. If you really care about resale, go apple better
And yes, if resale, generally local ROM will fetch better price, especially if you still got time on the warrenty. Alot of ppl can't be bothered with flashing and manual updating, and always have concerns if certain apps cannot function properly with flashed ROM
superio
Noted thanks for sharing bro.
Soulfly
I think is trace to the number of devices unlock previously. Last time I unlock mi9 it was immediately. Now second time unlock mi11u 48hours. I don't know maybe I wrong any new account after 2014 seems to be all set at 168hours.
I guess you're right. It tracks how many devices a person unlocks with one's Mi account. My CC9 Pro was the first xiaomi device I unlocked the bootloader then followed by my 2 sets of Mi 10 Ultra. The more devices I unlock. The waiting time all becomes the same which is 168 hours...
A5tuTe
Have had a shop flashed my CN mi 11u to global rom.
Found out that this causes Gpay unable to be functioned as the bootloader still on unlocked.
Can the gurus here help how to go about? TIA
Aicirt
sian1/2...168 hours !@#$%^&*(
Which rom you guys using ah ?
From miui.net i didnt see any mi 11 pro gobal stable. Only MI 11, Lite and ultra....
From xiaomi.eu.... i do see mi 11 pro.
Between miui.net and xiaomi.eu , can some pro here advise what's the difference ?
tkdboi
from what I read, only choice is to flash to EU Rom..
