JayBeeLwashere
- Feb 18, 2013
Those that having battery issues with 14.6 try delete the Apple Music and podcast app works for me
Hardware knowledge: This is common on a camera sensor with a larger sensor, this will also happen on every DSLR/Mirrorless camera because they using large sensors too.Hello guys, i am not sure if this has been discussed before. But today, i tried using my iphone 12 pro max to take a close up shot for the first time and shockingly, i realise it doesnt focus upon close-up.
I tried with samsung, regular ip12, both can achieve much better focus on close-up. Called apple support, they ask me force restart, update IOS version. Still doesnt improve anything.
Any guru can point me to the right direction??
Don't be so perseverant on battery health, no hardware can last 100% forever.Sian man battery life dropped to 97 liao
My batt at 100% lifespan lasted for 6 months after purchase, then suddenly drop to 96% over the last 2 months....Don't be so perseverant on battery health, no hardware can last 100% forever.
Almost 3 months drop 2% already not bad what? Drop about 16% in 2 years
oh dearDon't be so perseverant on battery health, no hardware can last 100% forever.
Check with u, are u using fast charge?Today checked, 97% now. Drop 1% from 98% within 3 weeks.. sob sob
Yes. Fast charge. But I got a friend with 12pro. Still holding 100% health and he uses it from the release. He uses fast charge too.Check with u, are u using fast charge?
You can’t tell the difference unless you’re downloading a very large file. Or playing some latency based games.Jus wanna check… anyone started adopting/using the new 5G standalone sim from ST to test out the 5G infra here?
Quite interested in the results as mine will be activated nxt wk.
