XIAOMI MI 11
tckrto
I did paynow, paylah, paywave, gpay, google opinion, map, assistant all working normally as global set. Thank you @KeYoKe for introducing this custom rom!
KeYoKe
no problem :s13: good things must share. everything working fine on EU rom
However, if china set flash global rom, safety net fail, cant use banking apps/gpay
dodongdodong
After unlock bootloader your phone should have been factory reset. Then boot in first but setup phone with only phone pw lock get ready for TWRP that's what I did. I didn't have to key pw for mi account leh.
Anyway welcome onboard. Enjoy the custom rom. While the rest still waiting for local set 😁
Cool, now you have unlocked bootloader. Some cannot take this thats why they wait for local set.
tckrto
To each his best. I wanted to wait for local set but the long waiting is too much. By the time local set launch maybe IPhone 13 come out liao.
KeYoKe
i dont see any issue with unlocked bootloader either unless you install magisk to root the phone
you can always relock the bootloader after flashing back the original region firmware which your phone comes with and lock it back
KeYoKe
Your friend uses trwp to flash ? or fastboot ? saw theres only rom for trwp on latest rom
twrp bro
since twrp out liao, they will release recovery rom starting from eu rom 12.5.7
during the beginning phase, can only install via fastboot, so they only install via fastboot rom. and if there is no custom recovery, you have to use a PC to update the firmware. with custom recovery, can just download the zip file, boot to recovery and install, and reboot to system after that. so much easier without using a PC
dappercivility
Same here. I was waiting and hoping local sets come soon. But no sound no picture, some say coming, some say not coming. There were some estimated prices floating around too and I found it too expensive, in the end just plunged for a used cn set.
dappercivility
I think China now like Japan, keep the best for their domestic market only. Export market no priority now.
tckrto
With shopee and lazada killing each other. I manage to get this cn set at 1.3k 12/512gb which I doubt local set can match the price. Adding this custom rom works identically like global set I have no regrets at all. And I get to show off all the photos taken using this new tech on social media platform lol.
dappercivility
Yeah lowest I saw was $1319 for the 256gb storage version. But need to wait for stocks....... The almost new set I got it $1270 and can immediately collect so I went for the used set.
Q10spy
There could be security flaws with unlocked bootloader. It could also be transferring a tiny fraction amount of money to a private account for every bank transaction you make. With so many eu rom users around the world, the coder is a millionaire.
KeYoKe
Then u can always dont unlock bro. To each his own...
But unlocking bootloader, is just open the door to root and modify some system components. As long as dont root, all is fine. You have to know what you are doing and what is those commands or actions for
Just to clear some air here...
ZhuTou!
Huh secretly transfer money to others?
Unheard of
tckrto
Is like a door having two layers of lock. First we unlock the steel gate which is the bootloader at this point still fine, then next once main door unlock aka rooting means security flaw liao.
These are what I understand aftering reading up here and there.
KeYoKe
Bingo. Good layman term explanation
