XIAOMI MI 11
juzzmee
juzzmee
Hi, thanks. Can I trouble you to point me to the correct YouTube video with the step by step instructions?
Thanks again
KeYoKe
tkboyz
Setedit app can download from app store.
Remember u only can set 60, 90 or 120.
Find "user_refresh_rate" key and change value to 90
Learn this from xda forum.
I never try other setting not sure what will happen so better stick to it lol.
Cool.. thx !
jungle_sg
My Mi 11 has updated to Miui 12.5.3 but I have noticed some language problem here on Settings, anyone face the same issue? How to resolve it? TIA
tckrto
thanks bro! hope I dun screw up. did you flash with twrp or just fastboot?
Now latest rom 12.5.7 only TWRP.
U still have 7 days or 2 days to learn. Bootloader unlock need to wait is not immediately available.
tkdboi
is the below steps correct to install fastboot first and then twrp?
Update your stock ROM to the latest via updater app first..
- Unlock your bootloader by Mi Unlock tool https://en.miui.com/unlock/
- Download our ROM zip file BETA or STABLE
- If you are on Windows: Right click on downloaded zip - Settings - Unblock zip content
- Unpack downloaded zip file in the PC
- Reboot your device to fastboot mode (press volume down + power)
- Connect to PC via original USB cable
- Run fastboot installation script as administrator from unpacked zip according your PC operating system
For Windows OS ./windows_fastboot_first_install_with_data_format.bat
TWRP install via fastboot command
Code:
fastboot boot twrp.img
For install ROM, just select in TWRP - Install - ROM zip -
tkdboi
Code:
sorry, I think below should be the right steps. please advise hehe
ROMs for devices with locked bootloader:
Unlock your first bootloader here http://en.miui.com/unlock/
Install TWRP via Fastboot mode, then install our ROM
Code:
fastboot flash recovery twrp.img
TWRP Recovery TWRP or TWRP.ME
FORMAT /data partition (NEVER wipe System or Persist!)
Copy our ROM to the internal storage
Install our ROM
Reboot
done
Installation via TWRP:
- Download zip to internal storage
- Updater - Menu (...) - Reboot to Recovery
- Install - Select zip
- Reboot
- Done
tkboyz
not sure if u guys faces these issue.. some app got notification icon but no sound..
unable to change whatsapp notification sound too
1)Ok figured out WhatsApp individual sound.
2) Example: Gmail.. got to go to setting and set sound for individual app. Else it's set to none on default. Leh chey
KeYoKe
Code:
Install our ROM
Reboot
done
- Reboot
- Done
This is basically correct!
tkboyz
Btw notifications works fine for u guys ?
I had to enable all individual app to autostart and set permission to allow sound one by one.
All apps installed with miui battery saver mode on by default in app settings.
Guess I gonna factory reset
tckrto
Have such phenomenon but just need those WeChat, WhatsApp, telegram, email etc to work. The rest like shopping notification not impt to me so I don't bother.
ZhuTou!
Its normal for xiaomi phone, every apps are batt saver by default
U just need to set those apps with push notification with auto start and no restriction for batt saver
Like whatsapp, wechat etc
The rest no need touch
tckrto
I got my smart devil hydrogel screen protector the finger print now is better! And the semi silver clear case is nice! Anyone wants cheap and good case and protector for mi 11 ultra can go taobao lookout for smart devil. Me not associated with them at all just for info. Just sharing my experience with them.
