I'm not sure about Oxygen OS but on Color OS (which is a sibling) there's this option under AOD's "Display options" to select:
- Power saving (which turns off the screen when it's stationary "for a while"
- Scheduled (I supposed you can set the timing)
- All day
Do you see this in the phone?
By the way you purchased 9 Pro or the normal 9? Interested to know how the 9 Pro is so far...
I found out why, i used the case the seller gave (transparent silicon standard case), and it covers abit too much, triggering the pocket mode sensor thats why the AOD having issues. Once i switched back to the stock case its alright lol. Still trying to figure out where is the pocket mode sensor.
I use the 9 Pro, switched from op5. so far, everything seems like an upgrade, honestly not that much that i can feel, op5 still working well, just buy in case my op5 died it would be troublesome.
Upside: 120hz, everything is smooth, camera is good, very customizable phone, feels good in hand, not too big, a cm bigger than op5 but screen size is around 40% more. nothing much to complain other than below.
downside: no led notification, need aod which is working fine for me now. and the other downside is just that the 120hz too smooth, sometimes in various apps will have some ads which takes up alot of bandwidth? not too sure, then the scrolling become very choppy/stutters alot, which is more apparent in op9p than op5.
as for maumu - i never download singpass so idk haha. NFC havent get the chance to use it, still waiting for a new credit card to be delivered first.
