is the below steps correct to install fastboot first and then twrp?
Update your stock ROM to the latest via updater app first..
- Unlock your bootloader by Mi Unlock tool
https://en.miui.com/unlock/
- Download our ROM zip file BETA or STABLE
- If you are on Windows: Right click on downloaded zip - Settings - Unblock zip content
- Unpack downloaded zip file in the PC
- Reboot your device to fastboot mode (press volume down + power)
- Connect to PC via original USB cable
- Run fastboot installation script as administrator from unpacked zip according your PC operating system
For Windows OS ./windows_fastboot_first_install_with_data_format.bat
TWRP install via fastboot command
Code:
fastboot boot twrp.img
For install ROM, just select in TWRP - Install - ROM zip -
