testart
- Jun 15, 2012
Thank you Dr.Vijay. I checked out the tip no. 11 and found all the thread started by me. Very good link.Check out tip no.11 here:-
https://forums.hardwarezone.com.sg/threads/some-tips-to-navigate-boards-pcw.6489501/
You can also search for them --- the advanced search is quite comprehensive.
You can also click your own profile user name and, click it again to land on the dedicated profile page -- that will give you options to see all your contributed posts/threads.
Just wanna ask one more thing which is one my favourite feature last time. I remember last time there was an advance search that has this feature which I can search all the thread started by a username and then indicate the minimum replies which I want. Example I just want find those thread started by me that has more than 100 replies. Then it will populate those thread that has min 100 replies.
How do I perform this kind of search now? The current one seem like search thread by "posted by".
EDIT: OK I know how to do it already. Just checked the tickbox "Display results as threads"
EDIT: OK. Though I found my thread with more than 100 replies but I also found thread that not started by me.
