gregory_choo
- Nov 7, 2007
I'm using it for my android tv, not an android box. Taking into account the system apps which can't be remove there is only half of the 8gb left to install apps. I don't even play around with apps, and i generally try to avoid side-loading stuff. All i have on the internal storage are apps that i need like netflix, apple tv, disney plus etc.
Even 1gb isn't a lot these days, try to install a game and half of that is gone. I also have a mibox which didn't fill up that fast because of less system apps.
whether it is android tv or android box, it is similar (almost the same).
normally there is 5GB internal storage left , it is actually a lot of storage for installation of apps. I can install 50 apps easily.
if you are only using netflix, apple tv, disney plus etc, 5GB should be more than sufficient. you should check whether you have wrongly configure the apps if the space is not suffcient.
If you want to play android games, it is better to buy nvidia shield.
