Hi bros & sises,
I recently move apartment, but still within Yishun, and had relocated my M1 Fibre 1Gbps service along.
My network setup:
M1 Huawei white box to Asus AC86U (main router)
AC86U connects to AC88U (wired) and a second AC86U to form AI Mesh.
In my old apartment, my gaming PC was connected to my main router directly via LAN cable, the speedtest usually hover between 800-900 mbps. Speed was good and I had no issue with gaming or video calls.
In my new apartment now, the same setup, but speedtest through my gaming PC is 300 - 400 mbps. I tried connecting directly to the main router LAN port via LAN cable (previous was through a switch) or tried using a laptop with LAN connection to another LAN port on the main router but the test results are the same.
M1 had sent their technician over and replace the Huawei white box, in their test, they said that issue is with my Asus router and speed test through the huawei box directly gives a 800+ mbps results. I tried switching the 2 AC86U over but the results are identical. Haven't tried to switch the AC88U over as main router but that is connected to my NAS, so a bit reluctant to try that.
Does anyone know what else can I try to locate the issue or improve my speed?
Thanks in advance.
