tckrto
- Oct 21, 2001
How's situation? Any findings?See my graph..
Batt not 0%. Charging line go dowards.
Looks like the battery is going bonkers. Another issue could be the charger or cable is faulty. Hopefully everything is ok bro...See my graph..
Updated! But the boot screen wait very long. Mine took 10mins to load up.
No pro sir. Actually I anyhow press only hope don't press wrongly. Lol
I downloaded via the phone update. I rebooted to recovery mode, chose install but can't find the file anywhere to update. Not sure if I did it correctly thoughTo update quite straight forward no need to wipe dalvik or format. Just install then select reboot system. And it's done.
There's no recovery. U need to boot into TWRP and update the rom like how we flash the first time. Just that no need to format or wipe dalvik for updating.I downloaded via the phone update. I rebooted to recovery mode, chose install but can't find the file anywhere to update. Not sure if I did it correctly though
Yup. Is like fresh install like that... Is normal... Dont panicUpdated! But the boot screen wait very long. Mine took 10mins to load up.
With KeYoKe's help, my phone has been updated. Thanks KeYoKe bro!There's no recovery. U need to boot into TWRP and update the rom like how we flash the first time. Just that no need to format or wipe dalvik for updating.
If u can't boot into TWRP means u miss out installing TWRP permanently. U have to repeat installing TWRP using adb "fastboot boot twrp.img" then boot into TWRP select "advance" and select "onekey inject TWRP"
If use netflix then will affect loBut widevine L1 certificate still missing in this update. Not sure how it affects but so far all banking apps I use is working.
You are welcome broWith KeYoKe's help, my phone has been updated. Thanks KeYoKe bro!
I checked drm is okay widevine L1 can show movie in hdr or Dolby vision. The missing information is in payment. So far I didn't encounter problem with paylah, paynow.If use netflix then will affect lo
Then i guess should be fine baI checked drm is okay widevine L1 can show movie in hdr or Dolby vision. The missing information is in payment. So far I didn't encounter problem with paylah, paynow.
Normal. Just turn off the notifications for microG baThanks to bro KeYoKe for guiding me how to flash twrp and the latest EU stable rom via WhatsApp. I've installed YouTube Vanced as well. I noticed that now I don't need to turn off optimization to install YouTube Vanced and MicroG. But I found out a problem with Vanced MicroG. When I turn off battery optimization, after awhile it will turn on on its own again. Anyone facing this same problem? Thanks...
Yeap i did turn off my wifi before registering, the account got linked to my phone, BUT, i cant verify the number. Thats the shitty thing, even if i try to set my wife's mobile number as a recovery phone, she cant receive verification sms as well. went through 34emails with Xiaomi global to try to fix it. they finally gave up and i have to send my phone back to china...not gonna go through this experience again after this. was suppose to be a happy month of June as i was on leave so i can enjoy my new phone,.Did u turn off wifi and use your mobile data to tie your handphone to account.
https://c.mi.com/thread-1635834-1-1.html
