XIAOMI MI 11
tckrto
See my graph..
Batt not 0%. Charging line go dowards.
How's situation? Any findings?
tckrto
To update quite straight forward no need to wipe dalvik or format. Just install then select reboot system. And it's done.
dappercivility
I downloaded via the phone update. I rebooted to recovery mode, chose install but can't find the file anywhere to update. Not sure if I did it correctly though
tckrto
There's no recovery. U need to boot into TWRP and update the rom like how we flash the first time. Just that no need to format or wipe dalvik for updating.
If u can't boot into TWRP means u miss out installing TWRP permanently. U have to repeat installing TWRP using adb "fastboot boot twrp.img" then boot into TWRP select "advance" and select "onekey inject TWRP"
dappercivility
With KeYoKe's help, my phone has been updated. Thanks KeYoKe bro!
tckrto
But widevine L1 certificate still missing in this update. Not sure how it affects but so far all banking apps I use is working.
tckrto
If use netflix then will affect lo
I checked drm is okay widevine L1 can show movie in hdr or Dolby vision. The missing information is in payment. So far I didn't encounter problem with paylah, paynow.
Soulfly
Thanks to bro KeYoKe for guiding me how to flash twrp and the latest EU stable rom via WhatsApp. I've installed YouTube Vanced as well. I noticed that now I don't need to turn off optimization to install YouTube Vanced and MicroG. But I found out a problem with Vanced MicroG. When I turn off battery optimization, after awhile it will turn on on its own again. Anyone facing this same problem? Thanks...
KeYoKe
Normal. Just turn off the notifications for microG ba
And ya dont need turn off optimizations for eu rom :s13:
Glad to help u solve it. Enjoy the phone bro!
Ah_Ming
any recommendations for screen protector on mi 11 ultra?
bought the smartdevil screen protector from lazada. fit is good but it reduces the sensitivity of the fingerprint sensor to almost unusable.
eggie87
Did u turn off wifi and use your mobile data to tie your handphone to account.
https://c.mi.com/thread-1635834-1-1.html
Yeap i did turn off my wifi before registering, the account got linked to my phone, BUT, i cant verify the number. Thats the shitty thing, even if i try to set my wife's mobile number as a recovery phone, she cant receive verification sms as well. went through 34emails with Xiaomi global to try to fix it. they finally gave up and i have to send my phone back to china...not gonna go through this experience again after this. was suppose to be a happy month of June as i was on leave so i can enjoy my new phone,.
eggie87
Im using starhub, My wife using singtel, both cant receive. Called up starhub to check for overseas number barring ,dont have.
eggie87
Bought mine from shopee, china brand, but its a matte hydrogel film, like silicon, but feels better than the sg overated X-ONE brand silicon film..worked well while i was using it.
