XIAOMI MI 11
tckrto
My mi 11 died suddenly... Hard reset also no reaction...sianz...
Local set? Cannot bootup? Any heat issues prior to dying? Sorry for asking so much. I offer my condolences in the mean time.
ZhuTou!
I wonder all the issue is it due to the superfast charging
Too high w phone cannot handle
Nakedtoes
Mine doesn't work at all. All I hear is the sound in the background of the movie on Netflix. But no PIP. Sian....
Need go setting enable picture in picture... The video play in my brave browser and vanced youtube both also can display above my other apps..
Soulfly
I found a way to make PIP work. First under Navigation, use Buttons. Then go watch a YouTube video and PIP automatically works. After that go to settings and set Gestures and PIP will work in both Buttons and Gestures mode. Miui is one of the most buggy Android skin I've ever seen and used. Some will say it has it's own character. I call it quirky. Hahahahaha...
Soulfly
One more thing, when you guys check files. Do you see your Whatsapp folder there? Mine wasn't. Even when I plug into my laptop. It was shown. I actually found the Whatsapp folder inside the Android folder. Is this a new Whatsapp thing? So i deleted and reinstalled Whatsapp a few times. Finally now when I click on files. I see the Whatsapp folder. And it shows on my laptop too...
eS.KuKu
can share how you guys download the update? the links from xiaomi.eu all like not working. download time all 8 hours and above.
tckrto
I use PC to download then transfer from PC to phone. Somehow use phone download the speed too slow.
Soulfly
How do you switch off the function at the top left corner of the control center, it keeps showing me how much data I've used. Thanks...
r0_ger
Ya local set. Plug in to boot or fast boot also cannot. It has always been quite hot and then suddenly ytd screen froze. Did a reboot but nothing happened.... The rest is history... Anyone has such issue before? Xiaomi service ctr helpful?
tckrto
My guess is mainboard fried liao. Go service center since local set.
No way. Being trying end up I change it to show number of steps count.
Soulfly
Most likely the motherboard is dead. Bring it to Xiaomi service centre. I don't know how's their service standard now but a few years ago, it was atrocious. Had the worst after sales service experience ever. That's when I told myself, with this kind of fxxx all service standard, I'm not going to get any local Xiaomi phones. It cost more and with such lousy customer service, who needs the warranty. And Xiaomi Singapore don't even bother bringing in the best phone models...
tckrto
Thanks for the reply. How did you change it to show number of steps count?
Press on the small triangle at the bottom right of the box for the data usage. Then the three options will come out for u to select.
