XIAOMI MI 11
Soulfly
Knn should have stick back to 12.5.7 at least everything works lol.
Edit: Updated to 5.10 bug still remain. Well just gotta learn to live with it 🤣
I saw the latest 12.5.10 stable update on my phone. So how do you update? Just download it on my phone? And then install using twrp? And then wipe dalvik cache?
tckrto
Download the rom into phone. Then boot to TWRP select install then reboot. No need wipe or format.
Stripy
Press on the small triangle at the bottom right of the box for the data usage. Then the three options will come out for u to select.
Questions....1) how do you get the enlarged buttons changed? No matter what I do - reverting back to the old setting - I cannot change the ones they've given me. 2) Where did you source the My data details to put in Control centre?
tckrto
I using xiaomi eu custom rom. If u on cn or global don't have the option to change it.
For xiaomi eu rom it's being there the first day when I flash the rom.
Soulfly
Thanks I did it already and the bugs are still there. Like you said, just got to live with it. Hahahaha...
Soulfly
Suddenly this file mace_cl_compiled_program.bin appeared in my root directory. Anyone have any idea what file is this and is it safe to delete?
garion80
Looking for help to flash my Mi 11 Pro, attempted to flash it and failed. Now stuck in Fastboot mode.
Appreciate if anyone in SG can meet up and help fix it.
Will compensate your time and effort with a token sum.
Apologies if this is not appropriate.
Thanks in advance.
tckrto
Thanks in advance.
Thanks in advance.
https://www.carousell.sg/p/android-services-152972163/
Try look carousell and check around. I not associated with the services. So don't ask me more information I don't have.
Computeron
any cn rom rec 5.8 or 5.9 updates?
mine still 5.7 which is april security.. now already july.
Soulfly
You on CN ROM? EU ROM is 5.10 now and the Spotify bug is still there. It will stop intermittently when you're texting on Whatsapp...
