XIAOMI MI 11
Exaita
i ordered 1 from taobao brand is X-IT waiting for it to arrive...hopefully by next week. The review quite good and says fingerprint still working after installation.
Exaita
Mine kek
tckrto
got link? is it the film type or u glass type u using?
Read HWZ Forum Rules!
Just search 闪魔 in taobao then go into their flagship store. I using hydrogel at the moment. Still waiting for the UV Glue glass protector. I have bought it but wife procrastinating shipment as she wants to buy other stuff but till to date nothing bought 😂.
Soulfly
Why flash eu instead of global rom?
If you prefer your phone to be like the Global version than you flash to Glboal ROM. But do note that in order to flash ROMS. You need to unlock your bootloader and with Global ROM, Google Pay might not work if you're using it. As for me, I don't use Google Pay. And with unlocked bootloader, apps like Netflix need to be sideloaded as well when you use Global ROM. With EU ROM, it is based on China ROM but without any bloatware and ads. And Google SafetyNet passes too. It works perfectly as though the bootloader is locked. So you won't have problems using Google Pay or downloading Netflix and other apps from the Play Store...
Exaita
Nope, I haven recontract to 5g plan. I thought 5g also won't be supported on 11 ultra :unsure:
eS.KuKu
Anyone got this WhatsApp issue whereby it show 2 names in the notification
on stock CN rom, my was like that for first few days. the problem automatically disappear after a few days. On my EU rom no such problems though
phiber
Either use mi cloud or google backup. Important are the contacts, WhatsApp msg, calendar, notes, photos and videos. Apps no need just redownload from app store.
Google backup does not work on CN rom... need to install EU ROM
shager
How will I know when I can upgrade to EU/Global from CN rom? Is it exactly to the hour? Thanks.
snoopy@singapore
The reason why I don't want eu rom because you need flash twrp ... Just unlocked bootloader and flash global safetynet will fail? I don't might stick on cn rom .. but found after update to latest version xiaomi removed out Google
