XIAOMI MI 11
tckrto
The reason why I don't want eu rom because you need flash twrp ... Just unlocked bootloader and flash global safetynet will fail? I don't might stick on cn rom .. but found after update to latest version xiaomi removed out Google
Wait what? U mean after updating to cn rom 12.5.10 xiaomi remove google play services?
snoopy@singapore
Sorry for my wrong information, once I done updating few day ago I found it was gone... But I did checked again just now... It appears again... the reason I found it gone because I can't backup my WhatsApp to Google drive... But it successfully now... Amazing
ZhuTou!
Why dun wan twrp?
Flagship model update wont affect google la
Soulfly
If you don't really use Google Pay. Just flash to Global ROM. I flashed my CC9 Pro Premium Edition, China version of Mi Note 10 Pro to Global ROM and everything works perfectly. And you get nomral OTA updates too. But as mentioned, I'm not sure if Google Pay works cos I don't use it...
Exaita
5g vs 4g, sitting at the same spot o_O
tckrto
Haha. I on EU ROM and getting this issue
I think google needs to validate your account and phone before certifying. I saw this phenomenon occur for a few people on xiaomi eu forum. The developer team ask those to wait for a day then certification pass. Just use safetynet to check can already.
tckrto
You on 4G lah. But can hook onto the 5G network just that phone didn't pay 5G network so only can use 4G speed.
Exaita
So 11 ultra support our 5g network coz I read somewhere says not supported.
tckrto
Just check out the cn set supported band vs our mobile band. I think is missing one band. Can't recall but definitely is not 66 cause 66 only use in USA.
Exaita
did some check and it seems on wikipedia our 5g is on N1,N78,N257 band currently which is supported.
stone1978
Hi guys, today my camera got this error message- insert SD card before using camera. How to solve this issue?
