XIAOMI MI 11
tckrto
shager
Do u mean the bootloader unlock time? If yes, I just wait for 168 hours .
Yes. Thanks. Wow so accurate.....exactly 168 hours...I thought if just 7 days then can unlock....but if go by hours... Then still not yet. I'll wait for it then.
tckrto
Yes. Thanks. Wow so accurate.....exactly 168 hours... I'll wait for it then.
Mine was 48hrs, just plug in and check when about 47hrs + 40mins then can unlock liao. U may try that. But since waited 168hrs liao just wait lah. Don't rush such flashing cause sometimes can forget important steps and soft brick the phone.
stone1978
Jialat, yesterday my wife saw my mi11 ultra camera and exchanged her iPhone XR for it.
Exaita
Anyone got issue with WhatsApp contact sometime not showing names but contact number?
Soulfly
Are you on CN ROM? Well what you can do is when you're on WhatsApp, click the message icon at the bottom right corner. It will then try to read your contacts. But if you're on CN ROM, you got to allow contact permission...
Exaita
Thanks I think I didn't grant enough permission earlier. Now no issue anymore.
ZhuTou!
For cn rom if happen again
U need to go google contact sync and set auto start and no restriction for batt saver
Exaita
What's the temperature of you peeps 11 ultra after charging and at standby?
Exaita
I thought why my phone damn hot even after unplugging, just discover something is bring u my battery. Trying to find it which app is causing this...
