I should think so. Once they are discontinued in a few years, prices will only stay there or go up even more.guys, do you think 321 or 50th snoopy will be able to retain value well?
I thought it went home with u on Tue or u got another one hahalets go home buddy.
Snoppy for sure.guys, do you think 321 or 50th snoopy will be able to retain value well?
Actually each month, there are only 2-3 Speedy 321s entering Singapore (boutique + wholesale), but the 50th Snoopy deliveries are around a few times of that, boutique only though.50th snoopy definitely retains value well. i think both does cos both is equally hard to get.
true, but for you no problem la!both also need connection and strings attached in order to be able to get hold. so its equally hard i feel.
Technically not LE but once discontinued it is a similar effect.lucky both not LE, the 2003 snoppy is a LE has 5441. 2015 snoppy has 1970 pcs.
Issue is there are always going to be flippers. AD setup is messed up, kinda supporting the flipping market.
