No best aircon installer and no best aircon brand too..After 300 pages you might have figured out there’s no such thing
once it reaches the point where you have to top up, more installers can do it already. Now everywhere going into R32 - they will be force to take it up to be relevant.Hi guys, just wondering if we opt for R32 and in the event, "touch wood" if we need gas top up, will we have difficulties to find repairman since it need a "special license" to do the work?
Wont spoil. Just not enough power to make all cold at the same time.Can I check… if Sys 4 compressor btu is 36k.
and sometimes all 4 blowers are on (12+9+9+9), will it spoil the compressor? Since all 4 blowers are 39k. or will it just not be as cold?
appreciate your answers.
right now my set up is 18k (living room), 12k bedroom 1, 9k bedroom 2, 9k bedroom 3.Wont spoil. Just not enough power to make all cold at the same time.
1. Calculate the amount of cooling capacity you need per room using the recommended formula belowFor Daikin MKM85 eco series...is it too weak /risky of not cold...if use system 4 for it...
Combination | Room 1 | Room 2 | Room 3 | Room 4 | Total |
2.5+2.5+2.5+2.5 | 1.81 (2.47) | 1.81 (2.47) | 1.81 (2.48) | 1.81 (2.47) | 7.24 |
2.5+2.5+2.5+3.5 | 1.67 (2.25) | 1.67 (2.25) | 1.67 (2.25) | 2.34 (3.15) | 7.36 |
2.5+2.5+2.5+5.0 | 1.53 (2.05) | 1.53 (2.05) | 1.53 (2.05) | 2.81 (3.77) | 7.4 |
2.5+2.5+2.5+6.0 | 1.37 (1.90) | 1.37 (1.90) | 1.37 (1.90) | 3.29 (4.54) | 7.4 |
2.5+2.5+2.5+7.1 | 1.27 (1.75) | 1.27 (1.75) | 1.27 (1.75) | 3.59 (4.99) | 7.4 |
2.5+2.5+3.5+3.5 | 1.48 (2.06) | 1.48 (2.06) | 2.07 (2.89) | 2.07 (2.89) | 7.1 |
2.5+2.5+3.5+5.0 | 1.37 (1.90) | 1.37 (1.90) | 1.92 (2.65) | 2.74 (3.49) | 7.4 |
2.5+2.5+3.5+6.0 | 1.28 (1.77) | 1.28 (1.77) | 1.79 (2.47) | 3.05 (4.23) | 7.4 |
2.5+2.5+3.5+7.1 | 1.19 (1.70) | 1.19 (1.70) | 1.66 (2.38) | 3.36 (4.82) | 7.4 |
2.5+2.5+5.0+5.0 | 1.25 (1.75) | 1.25 (1.75) | 2.30 (3.22) | 2.30 (3.22) | 7.1 |
2.5+3.5+3.5+3.5 | 1.37 (1.91) | 1.91 (2.67) | 1.91 (2.67) | 1.91 (2.67) | 7.1 |
2.5+3.5+3.5+5.0 | 1.28 (1.76) | 1.79 (2.47) | 1.79 (2.47) | 2.54 (3.24) | 7.4 |
2.5+3.5+3.5+6.0 | 1.19 (1.65) | 1.67 (2.31) | 1.67 (2.31) | 2.87 (3.96) | 7.4 |
3.5+3.5+3.5+3.5 | 1.78 (2.48) | 1.78 (2.48) | 1.78 (2.48) | 1.78 (2.48) | 7.12 |
3.5+3.5+3.5+5.0 | 1.67 (2.30) | 1.67 (2.30) | 1.67 (2.30) | 2.39 (3.03) | 7.4 |
Super super useful. Thank you sir1. Calculate the amount of cooling capacity you need per room using the recommended formula below
Cooling capacity required in kW = Total area to be air-conditioned [m2] ÷ 5
*to convert to Btu/hr, multiply the kW result by 3412
2. Then look at which combination suits your place. It has to be either equal or higher than your calculations.
3. Then compare the rated kW of the same combination per room against your calculations. Again, it has to be equal or higher than your calculations.
MKM85
Combination Room 1 Room 2 Room 3 Room 4 Total 2.5+2.5+2.5+2.5 1.81 (2.47) 1.81 (2.47) 1.81 (2.48) 1.81 (2.47) 7.242.5+2.5+2.5+3.5 1.67 (2.25) 1.67 (2.25) 1.67 (2.25) 2.34 (3.15) 7.362.5+2.5+2.5+5.0 1.53 (2.05) 1.53 (2.05) 1.53 (2.05) 2.81 (3.77) 7.42.5+2.5+2.5+6.0 1.37 (1.90) 1.37 (1.90) 1.37 (1.90) 3.29 (4.54) 7.42.5+2.5+2.5+7.1 1.27 (1.75) 1.27 (1.75) 1.27 (1.75) 3.59 (4.99) 7.42.5+2.5+3.5+3.5 1.48 (2.06) 1.48 (2.06) 2.07 (2.89) 2.07 (2.89) 7.12.5+2.5+3.5+5.0 1.37 (1.90) 1.37 (1.90) 1.92 (2.65) 2.74 (3.49) 7.42.5+2.5+3.5+6.0 1.28 (1.77) 1.28 (1.77) 1.79 (2.47) 3.05 (4.23) 7.42.5+2.5+3.5+7.1 1.19 (1.70) 1.19 (1.70) 1.66 (2.38) 3.36 (4.82) 7.42.5+2.5+5.0+5.0 1.25 (1.75) 1.25 (1.75) 2.30 (3.22) 2.30 (3.22) 7.12.5+3.5+3.5+3.5 1.37 (1.91) 1.91 (2.67) 1.91 (2.67) 1.91 (2.67) 7.12.5+3.5+3.5+5.0 1.28 (1.76) 1.79 (2.47) 1.79 (2.47) 2.54 (3.24) 7.42.5+3.5+3.5+6.0 1.19 (1.65) 1.67 (2.31) 1.67 (2.31) 2.87 (3.96) 7.43.5+3.5+3.5+3.5 1.78 (2.48) 1.78 (2.48) 1.78 (2.48) 1.78 (2.48) 7.123.5+3.5+3.5+5.0 1.67 (2.30) 1.67 (2.30) 1.67 (2.30) 2.39 (3.03) 7.4
You can see that many of the rated kW is lower than the FCU itself because rooms can be smaller, especially BTOs now. They probably only need around 6-7K BTU but the smallest FCU in the market is 9K.
So right size the CU against your rooms, not the FCU, else everyone has to get the MKM100 and Daikin might as well sell only MKM100.
You do need to get the FCU that is either equal or higher though.
super useful!1. Calculate the amount of cooling capacity you need per room using the recommended formula below
MKM85
shorter lifespan alsoCan I check… if Sys 4 compressor btu is 36k.
I think you should leave things as it is now and use the existing system until it uplorry. After that then change aircon system you want including the aircon piping.Hellooo!
I'm purchasing my upcoming resale flat and it comes with system 3 in 3 bedrooms
the current owner installed them 5years ago.
Should I:
1. Remain the system 3 and just add system 1 in living room or
2. replace everything and just do system 4 or
3. replace only pipings for current system 3 (remain the unit) and add system 1 in living room?
TIA!
btw i just checked with 2 aircon retailers and gain city.
model will release next year for Starmex R32 variant. Those can wait, you will have more options. However whether it comes with the smart feature by default is anyone's guess.
Yup, this is r32Gain city now selling this MITSUBISHI R32 model (in stock), not sure if it's starmex
https://www.gaincity.com/catalog/product/view/id/108585/s/T0158705/category/36/
This FP series consider as a new series compare to FN version? Or just using R32 gas only...Gain city now selling this MITSUBISHI R32 model (in stock), not sure if it's starmex
