- Sep 16, 2018
Hi Guys,
I'd like to check for any reviews of this router which my friend wants to pass over to me:
I'm currently on their 500MB plan with IPTV bundle, Using their old ALU ONT and FG7003GR Aztech router with Nokia Beacon 1 in Bridge Mode to get better coverage. Recently, the router started giving problems, it's like choking every morning and my download speeds are reduced to less than 40kBps, always have to reset the router very often. Called Singtel tech support and they insist that I sign a new plan and they will be able to upgrade my ONT and Router, hence my friend offered to pass me this router for me to replace the Aztech FG7003GR
Anyone knows if this router works decently well with similar default Singtel configuration to the FG7003? I believe it's just the VLAN tagging entry. And there's an indicator 'Mesh', so is this a real mesh router? Thanks.
Singtel Mesh Router is rated at AC1900. It should be plug and play with your ALU ONT. It should also work better than FG7003GR in terms of wireless speed and coverage. Read Page 2 and 3 of this thread to get more info.
It can mesh with Singtel Mesh Extender AC2600 but no point to get that.
