XIAOMI MI 11
Exaita
Don't find anything backing up, nv turn on Xiaomi cloud also. Whatsapp no much back up, wifi on all the time so pretty much all backup should be done.
dappercivility
Just updated to the latest EU Rom on Wed and improved batt life significantly. Previously the batt life was quite bad. Now it's alot better.
stone1978
After my wife took my mi11 ultra, I'm hesitating to buy another set for myself as I don't about mi11 ultra is not able to stop Whatsapp or any messaging apps photos for going into the phone storage otherwise it will be perfect.
ZhuTou!
Is there an andriod phone can stop them?
For xiaomi u can hide them
hyperloop
Hi resident experts, i have lurked around a long time can't contribute cos i don't know enough to contribute but you are all so knowledgeable. Here is my problem, I have a NFC enabled sim card with my EZ Link card on the sim, I tried to use it on the 11 Ultra but it keeps on going to Google Pay and hangs there, would any of you know a fix for this, phone was bought recently running stock chinese rom i just installed Google Play and a few google apps is all
stone1978
Oh I found the setting to disable it in WhatsApp under setting then chat and disable new media to appear in photo albums.
Exaita
Maybe go to your NFC or wallet setting change the default parent method. I change to hce and all my Google pay,simplygo,paywave all working without issue.
tckrto
I think in your case you have to disable your phone NFC before using SIM card NFC. It's interfering each other's function and usually the phone NFC takes precedence as the tag is bigger than sim card NFC.
Exaita
My media storage still on and off will suddenly consume alot of battery ... Turn off all type of sync already. Anyone got any issue with this =x on china rom
tckrto
Sorry can't help. Am on eu rom.
Soulfly
One question, do you guys charge your Mi 11/Mi 11 Ultra battery to 100%? I hardly charge my phone's battery to 100% to give it a longer lifespan but yesterday I charged it to 100% after updating to the latest EU stable ROM by accident. Placed my phone on the xiaomi wireless charger and within 15 mins it was fully charged from 49%. But I have to say at 100% with the new EU stable ROM. The battery lasted a long time...
PES1989
+1. Actually I wanted to know more about what others feel about the lifespan of the battery too. I'm not using this phone but have tried posting in other thread. Can understand why you wanted it to last longer since this is flagship phone.
https://charbycharge.com/how-often-...odern phone battery,will drop by roughly 20%.
Above link recommend keeping battery between 20-80 rule.
https://lauren-c-stephen.medium.com...e-lifespan-of-your-phone-battery-16c2af5ca59f
Above link recommend dark theme/mode for OLED & AMOLED phones to save battery.
tckrto
Just charge whenever u need more juice. A phone only last u max 2 yrs then u going to change a new one liao. If u want to have a phone to last u 3-4 yrs then most likely u don't need a smart phone. U just need Nokia 3310.
