Thoughts on local case brand SPYLABS ?
sglords
recently featured on LTT
somehow the design reminds me of parvum system
although oos on their website but still can find stock listed in shopee
Phen8210
Hope this is not one of the aftershock subsidiaries, if it is I 100% boycott
but most likely is not , because LTT is reviewing it hahaha..
wwenze
But then I boycott it if LTT is reviewing it
So either way...
ragnarok95
Senior Moderator
Senior Moderator
Google the company name and you will know.
y not?
nowadays its a trend for sff to fit full size gpu
too hot and cannot squeeze long big high wattage gpu inside.
now the trend is use M.2 for external GPU.
tan gu gu for proper M.2 GPU Dock instead of KNS Thunderbolt.
ragnarok95
Senior Moderator
Senior Moderator
Many are going ITX route. M2 style are for a niche market. People in these market usually think differently from others.
honestly i don't see the appeal of this casing.
they should go make a proper test bench casing instead.
