Residentvigilante
- Jan 5, 2021
both versions have pop out after watching movie and its really hard to exitif you are talking about beetv, there are only 2 versions listed on apktime.
install the mod extra version.both versions have pop out after watching movie and its really hard to exitinstra
not all shows can watch le. need to pay monthly.you may want to try WeTV, a tencents app meant for overseas customer. should be easier to subscribe.
if you don't need highest quality, can also try the app by guazitv. The app can be download from the official site at guazitv dot tv. There are 2 versions, suggest to run the TV version on TV box. At the moment, the app doesn't provide history and favourite functions, however the streaming speed is fast, and it is free.
who said all is free?? read carefully before you make noise.not all shows can watch le. need to pay monthly.![]()
Anyone knows about this? Thanks in advance!May I know if I need to root or load a new firmware on the a new tvbox (installed with android 10) which I bought online? Thinking of Buying a mecool box.
go to settings page and disable google playstore and google play service - your box will become lively again.Hi everyone, i got a 5yrs old beelink android box. Now its super laggy.
Any new android box to recommend? Thanks
Okie tonite i go disable. Thanksgo to settings page and disable google playstore and google play service - your box will become lively again.
Thanks a lot, Gregory, always so helpful !Q: May I know if I need to root or load a new firmware on the a new tvbox (installed with android 10) which I bought online? Thinking of Buying a mecool box.
A: Don't need to root, you can install and use most of the apps without rooting. Only certain apps need root. BTW, it is not recommended for new users to use these apps.
It is not necessary to update firmware, unless the current firmware is buggy.
install apktime on your box, try the top apps recommended by apktime
why the versions I used can?HI buddy, app (Bee TV) keeps telling me to use Titan video player. I've downloaded MX player but Bee TV Mod version doesn't allow me to set default player (no option in settings), how do I tell it to use MX player instead of Titan player?
TIA.
MagellanTVWhat's a good standalone app for watching documentaries?
Don't think it has chromecast.Does anybody have any opinion about MX1-SE, which seems to have Chromecast (Google Cast)?
Ref: https://www.aliexpress.com/item/4001267956704.html
Oh, looks good to me, subscription not too expensive.MagellanTV
