Hi, the right side of my Fiil t1 lite tends to die after less than an hour of listening.
I’ve tried cleaning the contact points on both the earphones and the case with rubbing alcohol.
Also tried charging the earphones (in the case) for an entire night but problem still persists.
The earphone case only has one small light that on the front that lights up when charging but I have no idea if the individual earphones are actually charging inside.
Is there any other way to rectify it?
Just an update to the situation:
I tested the Fiil T1 lite by connecting it to my laptop and watching a movie, the earphones lasted the whole 2hrs and more.
While I wrote about the earbuds dying in my initial post, that was when I used them for running.
This’s very weird, anyone know possibly why the earbuds will die less than 1hr when I’m running, but works fine when sitting at home, watching a movie?
