Psu or Mobo gone?
kundalini
Pc keep freezing 5 mins into the loading just idling on desktop, freezing with no errors. Got to do a hard shut down holding the power button, started with just simple browsing on the internet now loading game also hang. Gpu cpu ram is new.
Time to change psu?
Psu is like 3-4 years old
kundalini
ran a memtest no errors, any way to test ssd? i was loading up games in my another SSD also freeze.. now i cant load into dota2, loading into dota 2 confirm freeze, watching youtube videos sometime will freeze, audio still running then resume after few seconds. not psu problem?
psu is superflower 850 leadex gold
cpu is 4670k just bought 1 year ago
ssd is very long ago crucial & samsung ssd, 1 western digital hdd
mobo some asrock basic board many years ago
gpu 5600xt bought within last 1 year
previous 2 kingston ram fried, got 1 new crucial ram within last 6 month.
tried ocing my cpu little bit, but now resume back to normal
seems like anything basically on load freeze my pc, watching twitch video or loading into dota 2
Godeau
Try testing without your 5600xt and using only igpu
86technie
CPU Intel i5 4670k brought last year? Second hand?
Anyway since you have so many SSD:
- Try unplug one of them leaving only the drive that have OS.
- Run Crystalmark
https://crystalmark.info/en/software/crystaldiskmark/
Pairing Radeon 5600xt with i5 4670k is not a good and there will be bottleneck.
Opt to upgrade in the future if you have budget.
Get a pair of brand new Corsair Vengance DDR3-1600 RAM from shops like Fuwell.
Running two sticks or RAM would be better than one as with two sticks it will
run in dual channel mode.
tsteo77
You can check your psu/mobo voltage in the bios if their normal.
I'm curious what you did that fried your rams ?
kundalini
uinstalled the radeon adreline gpu driver software
event viewer show previous error with unable to start for AMD FUEL Services, AODDriver, Alipaladin, Malwarebyte services, then critical error Kernel-Power when i force shutdown
running occt stressing cpu for the last half an hour no freeze, cpu temps at around 75 degrees, usually idle at 40 plus degrees
running crystaldiskmark to stress the ssd also no freeze
a 100% way to freeze my comp is to start up dota 2, will hang/freeze while loading
seems to be on and off, previous week was freezing the moment i entered windows, yesterday was able to game and use normally for straight 10 hours. Seems like its better after I give it a rest when I am working instead of oning the PC for long periods of time.
https://ibb.co/r7mcgnGocct stress test for the 12v 5v 3.3v rails looks okay right?
86technie
Allocate one SSD, do a secure erase on it using the manufacturer Toolbox.
Install a fresh copy of Windows see how it goes.
I suspect one of the SSD have issue, and also run both Samsung and Cruical respective tool box.
Samsung is Samsung Magician, Crucial is Storage executive.
If there is wear level like around 20 - 30% than that SSD need to be replaced.
tsteo77
Your computer freezing due to super nature reason ? Just joking :) . Your voltages seem fine.
Try out techidiot's advise.
kundalini
after i delete my radeon adrenaline software seems to be able to get into dota now
will monitor for time being, ran RAM stress test on OCTT as well no problems, 32g crystal diskmark on both SSDs no crashing as well.
PSU seem to be unable to stress test on OCTT returning error on first sight, but at least able to play my dota now
kundalini
i think just wear and tear, since rams bein 4-5 years old, DDR3 kingston ram, 2 stick, Oced my 4560K from 3.4-3.8 previously not sure it affects,
kundalini
just then in dota was in game then it hang again, i force restart, when it loaded into desktop, it hanged immediately without even loading any programs..sigh..
previously it crash while was at the windows 7 bootup screen not even into windows, time to go run some ssd tools,
or is it time to go get some corsair rm 850w
thinking to upgrade to intel 11600 soon or should i go amd ryzen?
86technie
Very hard to rule out what is the issue.
BTW when updating the driver do disconnect from Internet, if not it will clash with Windows since it will auto install any missing driver.
SkyShroud
just noticed you did post your spec
you said ram gg previously
ram has lifetime warranty
did you send it to service center to check or you simply got a new ram and it worked thus assume the ram gg?
Yongkit
May I know if you have try to open your PC case and reconnect all cable and observe your cpu system fan still working?
Do you recently doing any OS system file cleaning or deletion?
wwenze
Follow these steps:
1) Enter BIOS
2) Disable Speedstep
3) Disable Turbo / Boost / whatever auto overclockiong
4) Disable C-States
Restart
