Psu or Mobo gone?
kundalini
Pc keep freezing 5 mins into the loading just idling on desktop, freezing with no errors. Got to do a hard shut down holding the power button, started with just simple browsing on the internet now loading game also hang. Gpu cpu ram is new.
Time to change psu?
Psu is like 3-4 years old
kundalini
when i run the OCCT PSU test something related to the gpu program will crash but still able to use no freeze. kept freezing when i loaded into desktop
will use the ddu to cleanup
anyway i unplugged the internet and the freezing stop since 2 3 hours ago, previously load into desktop immediately freeze
using laptop nao
86technie
Suggest you bring to a shop let them check.
However I would recommend upgrading the CPU and motherboard.
Pairing Intel i5 4690k with Radeon 5600XT is not very good.
tsteo77
haiz hang again after 4-5 hours idling duno what liao unplugged internet means not malware
tml go buy psu try
One last thing, you did not mention what mobo you using beside it's many years ago. If my memory did not fail,
from the voltage test image, it's asrock H81M mobo. If i'm correct, this mobo dont' seem to support 5600xt gpu.
It does not have pcie 3.0. Correct me if i'm wrong.
86technie
H81M indeed does not support PCIE3.0, It support PCIE2.0 so newer card will not be able to run full speed is one thing.
Newer cards recommend to run UEFI Boot than legacy/CSM mode, how to identify UEFI mode is.
Legacy/CSM mode you will see this screen after the BIOS screen.
UEFI mode wise is BIOS screen than there will be a circle underneath the brand logo.
TS the CPU and motherboard opt to change.
cscs3
ran a memtest no errors, any way to test ssd? i was loading up games in my another SSD also freeze.. now i cant load into dota2, loading into dota 2 confirm freeze, watching youtube videos sometime will freeze, audio still running then resume after few seconds. not psu problem?
psu is superflower 850 leadex gold
cpu is 4670k just bought 1 year ago
ssd is very long ago crucial & samsung ssd, 1 western digital hdd
mobo some asrock basic board many years ago
gpu 5600xt bought within last 1 year
previous 2 kingston ram fried, got 1 new crucial ram within last 6 month.
tried ocing my cpu little bit, but now resume back to normal
seems like anything basically on load freeze my pc, watching twitch video or loading into dota 2
If your SSD is from major maker. Use some utility to read the SSD smart data to see any abnormal.
cscs3
If you run with UEFI mode, part of the boot information is in the small hidden partition. Some PC call it boot manager.
kundalini
alright but no transport, will upgrade once have the $ soon, right now jus wanna get it to work so i can play game.. i been running the 4600xt for like several months without problems
Have you tried what I told you
tried disabling all the c state c1e turbo, went into dota still hang afterwhile
did crystaldiskmaker reads, crucial executive storage, samsung magicmaker, did the diagnostic tests, returned with no errors, healthy drives, right now it just freeze again after in game, restart go into desktop freeze again, unresponsive keyboard..
86technie
Two options for you:
- Bring to a shop let them take a look.
- Upgrade the motherboard to a second hand H87/H97/Z87/H97.
You can find such motherboard on Caurosell around $50 - $100 onwards.
- Downgrade the graphic card to GTX1660 or equalivent.
GTX1660 is PCIE3.0 to run on a PCIE2.0 it should be no problem.
If you want to savage the PC, I strongly suggest upgrade that H81 motherboard first
since you are not upgrading so soon.
Example of second hand motherboard like this one:
https://www.carousell.sg/p/gigabyte...gabyte motherboard&t-referrer_sort_by=popular
kundalini
i bought a corsair 850w psu replace, still hang, i plug out my 5600xt, still hang, onboards graphics will go undetected. open chrome, straight suddenly screen blank. keyboard mouse unresponsive, dvi monitor undetected
now i unplug GPU running new corsair psu, running in safe mode with no networking also just hang again.
Sometime need to press power switch many many time then will power up.. mobo up lorry?
also my casing earphone front connector actually the metal last time i opened up and cause it to bent now that connector like twisted and metal touching metal.. but shouldnt be an issue right
86technie
Change motherboard and try again.
Given the price you change here and there might as well one shot do a proper upgrade
but that is up to you.
kundalini
alright... thanks all for the input, i shall go and upgrade my mobo and cpu once payday is in..
goin for 11600 with some asrock mobo i guess, then a new casing
86technie
Go for Gigabyte, Asrock I am not a fan.
Example:
Intel i5 11400F + GIGABYTE B560M AORUS PRO - $244
CORSAIR VENGEANCE LPX 3200MHZ CL16 16GB - $155
Price from PCThemes.
Take note when change motherboard, Windows have to be reinstalled.
Different motherboard, different hardware not to mention huge generation gap.
For the time being, if you want to savage you can look for used Intel H87/Z87/H97/Z97 motherboard.
When you upgrade than sell away the CPU with the other motherboard.
The Asrock motherboard seems have stability issues so doubt any taker .
kundalini
Example:
nice brother.. will get the recommended..
pc theme can hack price? i just went today to get psu like fix price
casing cheap cheap $108 carbide series 275r airflow
need to get the wins 10 pro liao so expensive 200 bux, but guess can use for a long time
maybe i download win10 installer use my win7xp pro key since win 7 is a legit bought long time ago read online can use win7 key for win10
86technie
For home use, you don't need pro.
Pro version is for business/company use since it have features like Domain support.
Unless you need to join to company/school intranet than you need pro else
Home version will do fine.
tsteo77
Ya you can use win 7 pro key to upgrade to win10 pro. Create the installation media before you
change hardwares at here > https://www.microsoft.com/en-au/software-download/windows10
or this if you're game enough > https://tech-latest.com/ghost-spectre-windows-10-superlite-version/#21H1_2009_Preview_Release
wongminmin
When computer freeze without going into bsod, meaning is critical component.
Your voltage look ok, so PSU should be ok.
Assume your gpu is ok .......so can isolate this. So far, i never encounter computer freeze due to gpu...... :unsure:
since u tested with crystaldiskmaker.... ssd can be isolated.
so left ram, mobo
u can try to reseat ram.........Although ur new ram is 6 month old , new ram can also die instant when overheated....
motherboard is hard to test......but if everything tested ok, high chance is on mobo side...
most of typical freeze link to ram.
i read on another forum, freeze can also due to capacitor blown on the mobo.
my 2cents :)
cscs3
Not sure on crucial SSD. I am using Samsung, crystal disk utility reads the diagnostic data find. Also Samsung magic maker too.
