XIAOMI MI 11
Soulfly
For those of you that is looking for a uv glue tempered glass for your Mi 11 Ultra can try Blaze Mobile at Toa Payoh or Blazing Mobile at Far East Plaza. Both shops have the same owner. Had mine installed at the Toa Payoh store. It's actually a Mi 11 uv glue tempered glass. It fits perfectly and the fingerprint scanner works with no issues at all...
Kepller
Any recommendations for mi 11 ultra skins? I don't trust casing because im afraid it might scratch the phone like what it did for my previous few phones. If I end up with the mi 11 ultra, I'll paste skins on it and probably get a soft cloth pouch for easy slotting into pocket.
How does the adhesive on the skins and protectors work? Would they leave permanent residue after peeling them out 1-2 years later?
Soulfly
I've used dbrand skins before on my previous phones. It doesn't leave a sticky residue after peeling off the skin but overall, I'm not a fan of skins because it doesn't offer any protection at all. I still prefer using a good case. And to prevent any debris or dirt inside the case, I take my phone out every week from the case and give it a good wipe and I wipe the inside of the case too. The Mi 11 Ultra has ceramic back, so it's slightly more scratch resistant compared to glass. If you worry about the sides of the phone getting scratch, just do like what I mentioned earlier. Hope that helps...
Soulfly
Anyone looking for a brand new Xiaomi 80w+120w wireless charger full set, do drop me a private message. I've got a brand new set for sale...
stone1978
Today arrived. The small box is Full Glue Glass HD Anti Blue-ray Green Light Glass, pasted it perfectly but after awhile got bubbles. The other UV one is good but must be careful if the temper glass glue leaked out and pasted on the equipment then wasted 1 pc because can't can't again.
Soulfly
I think if done right. Uv glue tempered glass is better than none UV glue ones because non UV glue ones tend to have bubbles after awhile especially around the curved edges...
stone1978
Yeah I wasted 1 of my uv as it stick to the plastic holder frame ... =(
Yah mine too then the second one thought all good but ended up with a big bubble one the side and the anti blueray temper glass fingerprint sensor not very responsive.
Exaita
I am on my 2nd piece , also thought I did nicely until when I try to remove not fully dry...living with it first till I got more time to repaste. I order 5 piece at once :D
stone1978
Once the glue dried up on the glass cannot reuse again. It will turn into matte looking glass. one piece of mine ended up matte finish. Lol
Soulfly
Got it Thanks!
Glad you did. For me, I prefer to pay a bit more and let an expert do it instead of wasting a few pieces if I do it myself. The shop I recommended has really top notch service. When the guy stick the UV glue tempered glass, he noticed a very tiny speck of dust under the tempered glass. He told me it's not acceptable and went on to stick another brand new one for me...
stone1978
Wah 5 pieces cost $100+. Now I wait mine to crack then order again. I wonder if the UV glass dried is it easy to remove or not...
stone1978
How much he charge?
Exaita
Seems like m11u china rom gonna receive update on 13 Aug
ZhuTou!
Just use the free stock silicon case wont scratch ur phone
Having a case is impt to absorb impact
U wont know when u will knock it accidently or drop it
ksrokiller
Hi,is there a one click feature to back up all the files? My Mi11 wifi suddenly not working need to try factory reset if can resolve it.
