8K Cameras
Apparatus
Norman Chan
But you need to have a 8K monitor or display to playback 8k video recording if not than it is meaningless.
Apparatus
NIKON Z9 to have 8K@60fps
Video performance is equally impressive. The Z9 will be able to capture 8K at 30p at launch, along with oversampled 4K 30p from an 8K capture that should be incredibly sharp. If you don't mind pixel binning or line skipping, it will also be able to capture 4K at up to 120 fps.
Nikon plans to introduce a future firmware update that will enable 12-bit 8K 60fps capture in a new, proprietary N-RAW format or using Apple ProRes RAW HQ capture at 4K/60p. Nikon promises that you'll be able to capture the oversampled 4K/30p for more than two hours at "normal" temperatures.
https://www.engadget.com/nikon-offi...-video-and-20-fps-burst-speeds-125237569.html
The Nikon Z9 has been tested to video record 8K@30fps for about 1.5 hrs continuously without overheat, something which the current Canon and Sony (both 8K@30fps) cameras cannot do. Watch the video below
Key Specifications​
  • 45.7MP Stacked CMOS sensor
  • 30 fps JPEG shooting
  • 20 fps Raw shooting (for over 1000 compressed Raws)
  • 120 fps JPEG shooting at 11MP resolution
  • 8K/30p capture and 4K-from-8K, with ProRes 422 HQ option
  • 8K/60p, 12-bit 8K N-Raw and 4K ProRes RAW to be added with f/w
  • Internal 10-bit N-Log and HLG capture
  • 3.69M dot OLED EVF with reduced lag and greater brightness
  • XM dot rear LCD with multi-directional tilt
  • Twin CFexpress Type B card slots
  • Full-time electronic shutter camera
  • Sensor shield to protect sensor
The Nikon Z9 will be available before the end of 2021 (in the US, at least), with a recommended price of $5500, body only.
Reviews
https://www.dpreview.com/reviews/ni...led-look-at-nikon-s-new-pro-mirrorless-camera
https://www.newsshooter.com/2021/10/28/nikon-z9-8k-60p-prores-422-hq-internal-raw-recording/
Grindlewaltz
Finally more 8K Cameras! Can't wait for them to get more affordable. For now I'm good with my A7s iii.
Apparatus
CANON EOS R5 C also can record in 8K@60fps, but needs an external power supply (e.g. Anker PowerCore+ 26800mAh PD 45W power bank) to do that. By itself, it can record 8K@30fps max. It costs S$6599
https://sg.canon/en/consumer/eos-r5-c/product
Quote
Supports 8K/60P Internal RAW Recording
The 8K sensor and DIGIC X processor produce high-quality video at up to 8K/60P. Use of the Cinema RAW Light format with its high-efficiency mode enables internal card recording without an external recorder.
Unquote
It is lighter, smaller and cheaper than NIKON Z9
FI, NIKON has released its Z9 v2.0 latest firmware which allows users to shoot in 8K@60fps
RyanJ
Time to revisit LTO and Sony Optical for storage of massive files ..
Apparatus
Got a local quote for the CANON R5 C (w 8K@60 fps video recording)
1) Body - $6149
2) RF Lens 24mm - 70mm f2.8L IS USM - $3019
3) SANDISK 512GB Extreme Pro CFexpress Card Type B - $910 (256GB is $607)
4) SANDISK Extreme Pro CFExpress Card Reader - $77
5) Anker PowerCore+ 26800mAh PD 45W power bank - $189
So, total damage is $10 344
Using the online video calculator below
https://www.videoproc.com/edit-4k-video/video-size-calculator.htm
and keying in the relevant data for the highest resolution of 8K@60 fps
Resolution : 8192 x 4320
Video Length : 30 min
Frame Rate : 60 fps
Bit Rate : 2570 Mbps (https://downloads.canon.com/nw/camera/products/cinema-eos/x-eos-r5-c/EOSR5C_specifications.pdf)
Total file size is 564.26 GB
