dreamz13
- Mar 22, 2002
StockAre u on debloat or stock?![]()
Than maybe have to do the usual reset and try again.Stock
Yes I also faced this random reboots. Seems like its related to Spotify? Didn't use nfc when it happened.Seems like phone became unstable after update. My phone rebooted on its own a few time today already. I was only listening to Spotify and reading some articles.
Same here but not limited to Spotify. I encounter reboot problem with other music player as well. The phone will reboot when the music is playing and I attempt to off the screen with the power button. Seems like I cannot play music with screen off now with the updated F3...Yes I also faced this random reboots. Seems like its related to Spotify? Didn't use nfc when it happened.
I tried rebooting the phone and the problem seems to go away. Will monitor for a while more to see if it comes back.Same here but not limited to Spotify. I encounter reboot problem with other music player as well. The phone will reboot when the music is playing and I attempt to off the screen with the power button. Seems like I cannot play music with screen off now with the updated F3...![]()
i'm able to check in now after reading ur post.I have the same problem, but I found a way to be able to successfully tap in today. Try a couple of places earlier today and it works for me. The trick is, tap the safe entry sensor with F3 power button. Means bring the phone very near safe entry sensor with the power button/fingerprint sensor facing it. Try and let me know if it works for u![]()
damn i haven't received the update yet.... how to check? from settings?Poco f3 12.5 enchanced edition is here! Just updated. Aug 2021 google patch.
Hi, I used the same method to check in and out. Seems to work fine for me. Try to move the phone around abit to find the optimal spot or speed of tapping.i'm able to check in now after reading ur post.
but not able to check out (the blue safe entry gantry)... anyone of u managed to check out?
ok noted, will try againHi, I used the same method to check in and out. Seems to work fine for me. Try to move the phone around abit to find the optimal spot or speed of tapping.
Yeah settings, about phonedamn i haven't received the update yet.... how to check? from settings?
hmm weird it says no new updates sian. i guess i gotta wait for it to be rolled out to my phone.Yeah settings, about phone
I also disabled it too. Guess it was enabled by default after the update. Though I haven't experienced any reboots for past two days as I haven't used Spotify.Yes I disabled it too and the reboots stopped for now - did not realise that it was enabled by default after updating (I don't recall enabling it)
https://www.notebookcheck.net/MIUI-...ots-on-some-POCO-F3-smartphones.559036.0.htmlSeems like phone became unstable after update. My phone rebooted on its own a few time today already. I was only listening to Spotify and reading some articles.
"Turning off auto-brightness has been touted as a potential workaround, as has disabling MIUI's memory extension feature."
