amazingone
- Jan 14, 2015
Mine is on July security updateCurrently on nov security update it seems.
Hi all, anyone had any issue using the qr scanner for mate 10?
I have manage to found the scanner but it hardly was usage and wasn't able to scan any qr code after AI Lens got updated
u are right. mine also same.. weird that early this year, suppose to receive nov update.Mine is on July security update
The Mate series seems to be built like a tank.
My Mate 9 is still going strong as a backup phone and my Mate 20 Pro still runs very fast despite 2 years+ old.
Hey there, any mate 10 pro user experience their battery bloated up?
Mine just did this morning and was thinking what to do with it and their service centre is close today
Once the phone has been sent for servicing that requires dismantling the phone, the IP ratings will be lost.Is it true that sending the phone to huawei servicing then it will lose the water resistant ability?
Am having issues with the volume down button and power button on my Mate 10 too. Does the $80 includes the changing of the button too?Am at the Huawei service center. The power button has become increasingly difficult to press. The cost of changing the screen and battery is $80+. Decided to go ahead. Since they are charging $50 to change the battery only, it works out to be $30+ for a new screen. Quite lazy to do research for a new phone and don't really want to spend for a new phone either.
It's $87.10.Am having issues with the volume down button and power button on my Mate 10 too. Does the $80 includes the changing of the button too?
Do they factory reset your Mate 10 for the servicing?It's $87.10.
They said it's the screen that's causing the buttons issue. And when they removed the back cover, the paint came off!!! So it became a transparent back. They wanted to charge me for a new cover. I said it's their quality issue. Their quality won't last more than 2 years? They later waived the back cover fee.
Am waiting to collect my phone now. Will update again later.
My previous LG phone lasted me approximate 4-5 years without issues. I just had to change the (removable) battery.
Edit: They said it's one set of screen plus buttons plus battery so the buttons are new too.
Have to. Backup your phone.Do they factory reset your Mate 10 for the servicing?
