iPhone 13 Series
Whizdom
hi . need advice. I jumping ship from android (coming from note 10+) and intending to get this iP13.
but I'm not sure which one to get either the 13p or 13pm ?
past few years been using a big size phone esp note series. if I were to get the 13p bit small or is it slightly same? or 13pm more huge?
Read HWZ Forum Rules!
Tukatuz
Why not go to any Apple store and check out the iPhone 12 Pro and Pro Max to have a feel since the diff is not much compare to iPhone 13 pro/pro Max. Can even compare it with your Note 10+.
iPhone 12 Pro
Dimensions146.7 x 71.5 x 7.4 mm (5.78 x 2.81 x 0.29 in)
Weight189 g (6.67 oz)
iPhone 13 Pro
Dimensions146.7 x 71.5 x 7.7 mm (5.78 x 2.81 x 0.30 in)
Weight204 g (7.20 oz)
iPhone 12 Pro Max
Dimensions160.8 x 78.1 x 7.4 mm (6.33 x 3.07 x 0.29 in)
Weight228 g (8.04 oz)
iPhone 13 Pro Max
Dimensions160.8 x 78.1 x 7.7 mm (6.33 x 3.07 x 0.30 in)
Weight240 g (8.47 oz)
Fellowes
nope surprisingly.... instead our neighbor will get it before us (Msia)
Malaysia got Instagram reels and Instagram music before us as well. Idk what with those slow rollout of features to Singapore 😅 Maybe we first world nation but too small.
Fellowes
is it need to change to the 5G sim card then can connect to Singtel's SA network?
When you sign up new plan telco will auto give you 1x free replacement of 5G SIM Card. Only with the new 5G SIM card then you can connect to the 5G SA network, if not when using your older 4G SIM card it can only connect to 5G NSA.
Chevalier
Currently on 12PM liao.
Wanna go smaller, but dont wanna give up on the battery life of the Pro Max haha
I’m
in the same position as you. so I did some research and use the comparison tool on the Apple website. the iPhone 13 pro has better battery life than the 12 pro max! I’m sold! the 13 pro for me!
Op_Valkyrie
Hang on, so u are saying regardless of the hardware (phone) those that are using the nano sim from 3/4G era will need to change to a new nano sim to be able to use the 5G SA network?
KeYoKe
yea. a bit sad really... lets hope will roll out to us soon lor then can boost apple watch sales also ma
battledome64
So recontract have to pay $37 + GST to Singtelshop to get 5G SIM card?
ragnarok95
Senior Moderator
Senior Moderator
13pro max is 4350mAh, biggest on a iphone. Is there still a reason to get smaller one??? :D :D
